external USB drive
How do you ummount a USB drive. In the previous version, you would press the left arrow to unmount. With the latest version, there is no such option.
Another question:How Do I mount :wink: ??
Doing how explained with the Terminal, I get this message:
t-h-macbook:~ TH$ ssh frontrow@appletv.local
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that the RSA host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
36:06:a4:a3:0c:73:01:fc:a1:e7:01:7f:be:1c:8d:5d.
Please contact your system administrator.
Add correct host key in /Users/TH/.ssh/known_hosts to get rid of this message.
Offending key in /Users/TH/.ssh/known_hosts:1
RSA host key for appletv.local has changed and you have requested strict checking.
Host key verification failed.
What can I do? I am really a beginner with this ssh stuff.
1.000 Thanks
You have to erase a hidden file located at /Users/TH/.ssh
For this, choose finder > go > go to folder, then enter ‘/Users/user-name/.ssh’ (replace user_name by your user name, TH?)and erase the file ‘known_hosts’
You will be able to connect to your ATV.
Hope it helps,
Franck
