External Hard Drives
I am a new user. So if you have multiple external hard drives connected to an iMac computer will Infuse 7 automatically find all the connected drives and show this content? Or do you have to point it to an individual drive? I would think you should be able to select which drives you want Infuse to access but I am not sure how to do that as I don’t see anything in the settings that show the attached hard drives.
Thanks for your help.
You’ll have to set each drive up as a share.
Here’s the users guide on how to stream from a Mac.
This was very helpful and solved my problem. Thank you very much.
