Extended Dolby Vision gone
I was reading about extended Dolby vision on some older posts. And I found that it doesn’t exist anymore on Infuse, and more surprisingly can’t find any mention of it disappearing on this forum. So why did it go?
@GaryHowe
It’s basically baked into the app now since Apple started to support profile 8 natively. (Previously Infuse were doing an on the fly conversion for profile 8.) This pretty much made the setting redundant.
By default if Infuse can play the file as Dolby vision (so most Profiles 5 & 8) it will.
For profile 7 it will use the HDR fallback.
Okay thanks. But I’ve got a Dolby vision profile 8.1 file that won’t play as Dolby vision. The Dolby Vision logo appears on screen, but it absolutely is not Dolby vision, it’s HDR. Any ideas?
Could you run that video through mediainfo and post the results here?
Sure, here it is.
General
Complete name : Trap 2024 2160p WEB-DL DDP5 1 Atmos DV HDR H 265-FLUX.mkv
Format : Matroska
Format version : Version 4
File size : 18.7 GiB
Duration : 1 h 45 min
Overall bit rate : 25.4 Mb/s
Frame rate : 23.976 FPS
Writing application : mkvmerge v85.0 (‘Shame For You’) 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video
Format : HEVC
Format profile : Main 10
Format level : 5
Format tier : High
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile B, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 24.2 Mb/s
Width : 3 840 pixels
Height : 2 076 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.126
Stream size : 17.7 GiB (95%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 246 cd/m2
Maximum Frame-Average Light Level : 36 cd/m2
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Format settings : Big
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 577 MiB (3%)
Language : English
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Title : SDH
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Language : German (DE)
Default : No
Forced : No
Text #4
Format : UTF-8
Title : Latin American
Language : Spanish (Latin America)
Default : No
Forced : No
Text #5
Format : UTF-8
Language : French (FR)
Default : No
Forced : No
Menu
_00_00_00_000 : en:Chapter 01
_00_06_24_592 : en:Chapter 02
_00_12_51_604 : en:Chapter 03
_00_19_26_624 : en:Chapter 04
_00_25_14_097 : en:Chapter 05
_00_34_15_847 : en:Chapter 06
_00_40_16_833 : en:Chapter 07
_00_46_44_179 : en:Chapter 08
_00_52_41_119 : en:Chapter 09
_00_58_42_313 : en:Chapter 10
_01_06_04_589 : en:Chapter 11
_01_11_15_817 : en:Chapter 12
_01_16_41_017 : en:Chapter 13
_01_22_59_354 : en:Chapter 14
_01_30_33_558 : en:Chapter 15
_01_37_58_294 : en:Chapter 16
Is that what you wanted?
Which model Apple TV do you have?
Can you describe the issue you are seeing with the picture when playing this video?
It’s the latest Apple TV 4K only a few months old. The issue is what I’ve already said, it’s not playing as Dolby Vision. The Dolby Vision logo comes up but it isn’t Dolby Vision it’s HDR. It has none of the vibrancy and brightness of Dolby vision and if I change the Apple TV to HDR the picture looks exactly the same as when it’s supposedly playing in Dolby vision
There are some video encodes in which Dolby Vision basically does nothing. How do you know on this specific video it is supposed to look “better” than HDR?
if the brightest content in this video is actually 246 nits, then it’s basically SDR.
Okay thanks. So the problem is that it’s just a crap quality file by the sound of it.
