Error when installing Smart Installer
I get an error when tryingt to install the Smart Installer. From the log:
2009-06-10 22:21:47.084 nitoHelper[281] Root filesystem already writable
2009-06-10 22:21:48.499 nitoHelper[281] mach_kernel.prelink already patched or unrecognized
2009-06-10 22:21:48.510 nitoHelper[281] kextloader already installed!
2009-06-10 22:21:48.732 nitoHelper[281] bins installed successfully!
2009-06-10 22:21:49.087 nitoHelper[281] XML parser error:
Unexpected character h at line 1
Old-style plist parser error:
Unexpected ‘;’ or ‘=’ after key at line 1
2009-06-10 22:21:49.087 nitoHelper[281] mount: /Users/frontrow/Documents/MacOSXUpdCombo10.4.9Intel.dmg failed
The file MacOSXUpdCombo10.4.9Intel.dmg is about 93.7Mb on my ATV. When I look it up at http://www.apple.com/downloads/macosx/apple/macosx_updates/macosx1049comboupdateintel.html its 310Mb
I am a Windows user so i don’t have the file on any other mac. Any ideas?
I started off from the beginning which solved the problem.
  1. Reset to factory settings (ATV 1.0)
  2. Update to latest version ATV 2.3.1
  3. Installed aTV Flash 3.5.5
  4. Installed nitoTV Smart Installer
When I did it the first time I installed other application before I installed the nitoTV Smart Installer.
Maybe this can help someone with the same problem.
/Jonas
