Installed aTVFlash yesterday with no apparent problems. Updated Boxee with both updates, oldest one first and then beta upon second thought. XBMC will definitely open and seems to work. When opening Boxee get this: “Error: Cannot lauch XBMC/Boxee from path: /Applications/Boxee.app/Contents/MacOS/Boxee”. This gets confusing and am not sure it matters, but other computers on network use XP. Point me off in right direction.
I’d recommend restarting the AppleTV (disconnect power) and re-run the Boxee beta installer (accessible through XBMC/Boxee → Downloads menu).
That worked! Thank you…
