Error entering DFU mode
Hey guys, so im trying to jailbreak my ATV 2 running 5.3.
I have the latest Seas0npass, iTunes, drivers, etc.
When I try to jailbreak it gets stuck on the upload screen and then I get a pop up that says “error entering DFU mode”
I have tried different usb ports, and different micro usb cables.
Any help is appreciated.
Thanks!
Try upgrading to latest firmware using iTunes before jailbreaking.
I thought that you couldn’t jailbreak anything higher than 5.3 though. Am I mistaken?
You can (currently) jailbreak from any version to 5.3 without saved blobs. In other words, the version you are currently running is irrelevant.
So i updated the firmware in itunes, tried ita again, but im still getting the same error
Are you sure it’s an ATV2 ? Are you using a MAC or PC?
One way around this is see if seasonpass created a .ipsw file (do a search of your computer). If it did, put your ATV in to DFU mode, open itunes. hold shift+click restore, then choose that created file.
Its an AT2 I’ve jailbroken it before.
I am on a pc and i dont have a mac available for my use,
Also i tried to just restore the file in itunes, and it just gets stuck on the “Verifying restore with apple”
Did anybody find the solution for this issue? I am facing this issue now.
