I’ve just completed a clean install but I’m getting an error when trying to install some of the features from ATV Flash, for example Couch Surfer Pro, Infuse
The error I am getting is
E: dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem
How do I fix this?
im have the same issue. im trying to install nitotv but the installation fails and the log reads "E: dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem.
First try re-instaling you ATVFlash to see if that helps, if not, you need some sort of “terminal” program, Putty works good on PC. Jot down your ATV address, open Putty, log-in with root, PASSWORD=alpine, then issue that command (dpkg --configure -a)
I just googled this…The Terminal is a program included with all versions of Mac OS X. It is located in the Utilities folder within the Applications folder.
