Error 9.100 again
Hi guys I stumbled on the infamous error 9.100 again. Did an update from 5.2 to 5.3 as I was on 5.2 for ages and wanted to upgrade to 5.3 as it is still signed (anybody have an idea why exactly?).
Anyway, the ATV2 is jailbroken again and all is working but not the upload of files by aTV Flash Black. Installation fails and I get the error 9.100.
Please see the error log. Seems like something wrong with Cydia?
2015-04-27 02:03:45 -[VersionCheckPluginPane willEnterPane:]
2015-04-27 02:03:45 -[VersionCheckPluginPane sendRequest]
2015-04-27 02:03:45 -[VersionCheckPluginPane connectionDidFinishLoading:]
2015-04-27 02:03:45 Current version = 2.5, latest version = 2.5
2015-04-27 02:03:45 -[VersionCheckPluginPane showSuccess]
2015-04-27 02:03:52 -[AppleTVInstallerPluginPane willEnterPane:]
2015-04-27 02:03:52 -[AppleTVInstallerPluginPane startSearch]
2015-04-27 02:03:52 -[AppleTVInstallerPluginPane netServiceBrowser:didFindService:moreComing:] service <NSNetService 0x7fcedad920e0> local. _raop._tcp. B817C2CEFDB0@Apple TV
2015-04-27 02:03:52 -[AppleTVInstallerPluginPane netServiceBrowser:didFindService:moreComing:] service <NSNetService 0x7fcedf8c35a0> local. _raop._tcp. 00F76FD7559D@AirPort Express van Walter
2015-04-27 02:03:53 -[AppleTVInstallerPluginPane serviceObjectResolutionList:finishedWithNewServiceObjects:] services (
“<ServiceObject: 0x7fcedce4b240>Apple TV (192.168.0.63)”
2015-04-27 02:03:53 -[AppleTVInstallerPluginPane setupPaneControlType:] type 1
2015-04-27 02:03:55 -[AppleTVInstallerPluginPane shouldExitPane:]
2015-04-27 02:03:55 -[AppleTVInstallerPluginPane shouldExitPane:] count 1 selected 0
2015-04-27 02:03:55 -[AppleTVInstallerPluginPane shouldExitPane:] set ip 192.168.0.63 port 5000
2015-04-27 02:03:55 Installer Settings = <SharedSettings: 0x7fcedcf36440>
2015-04-27 02:03:55 -[AppleTVInstallerUploadPluginPane willEnterPane:] upload 0
2015-04-27 02:03:55 Upload settings = <SharedSettings: 0x7fcedcf36440>
2015-04-27 02:03:55 -[AppleTVInstallerUploadPluginPane showPaneControlType:] type 1
2015-04-27 02:03:55 -[AppleTVInstallerUploadPluginPane uploadFiles]
2015-04-27 02:03:55 Source = /tmp/com.apple.installerKC3QlYjT/AppleTVInstallerUploadPlugin.bundle/Contents/Resources/payload.tar
2015-04-27 02:03:55 -[AppleTVInstallerUploadPluginPane uploadFiles] service <SshUploadService: 0x7fcedcd8f0f0> ip 192.168.0.63
2015-04-27 02:03:55 -[SshUploadService startFileUploadToHostIP:userName:userPassword:localFilePath:remoteFilePath:synchronous:] ip 192.168.0.63
2015-04-27 02:03:55 Host ip = 192.168.0.63
2015-04-27 02:03:55 -[SshUploadService uploadSynchronously] testing connection to port 5000
2015-04-27 02:03:55 -[SshUploadService uploadSynchronously] test connection succeded
2015-04-27 02:03:56 Fingerprint:
2015-04-27 02:03:56 executing remote command “mkdir -p /User/tmp”
2015-04-27 02:03:56 ExecuteRemoteCommand exec rc 0
2015-04-27 02:03:56 ExecuteRemoteCommand read rc 0
2015-04-27 02:03:56 ExecuteRemoteCommand exit status 0
2015-04-27 02:03:56 executing remote command “tar -C /User/tmp/ -xvf /User/tmp/payload.tar”
2015-04-27 02:03:56 Command output:
./._com.firecore.sources_1.0.deb
./com.firecore.sources_1.0.deb
./._org.awkwardtv_0-1.deb
./org.awkwardtv_0-1.deb
./._org.xbmc.repo_0-1.deb
./org.xbmc.repo_0-1.deb
2015-04-27 02:03:56 executing remote command “dpkg -i /User/tmp/com.firecore.sources_1.0.deb”
2015-04-27 02:03:57 ExecuteRemoteCommand read rc 0
2015-04-27 02:03:57 ExecuteRemoteCommand exit status 0
2015-04-27 02:03:57 Command output:
(Reading database … 1317 files and directories currently installed.)
Preparing to replace com.firecore.sources 1.0 (using …/com.firecore.sources_1.0.deb) …
Unpacking replacement com.firecore.sources …
Setting up com.firecore.sources (1.0) …
2015-04-27 02:03:57 executing remote command “dpkg -i /User/tmp/org.awkwardtv_0-1.deb”
2015-04-27 02:03:57 ExecuteRemoteCommand exec rc 0
2015-04-27 02:03:58 Command output:
Preparing to replace org.awkwardtv 0-1 (using …/User/tmp/org.awkwardtv_0-1.deb) …
Unpacking replacement org.awkwardtv …
Setting up org.awkwardtv (0-1) …
2015-04-27 02:03:58 executing remote command “dpkg -i /User/tmp/org.xbmc.repo_0-1.deb”
2015-04-27 02:03:58 ExecuteRemoteCommand exec rc 0
2015-04-27 02:03:58 ExecuteRemoteCommand read rc 0
2015-04-27 02:03:58 ExecuteRemoteCommand exit status 0
Preparing to replace org.xbmc.repo 0-1 (using …/User/tmp/org.xbmc.repo_0-1.deb) …
Unpacking replacement org.xbmc.repo …
Setting up org.xbmc.repo (0-1) …
2015-04-27 02:03:58 executing remote command “apt-get -y update”
2015-04-27 02:04:02 ExecuteRemoteCommand read rc 0
2015-04-27 02:04:02 ExecuteRemoteCommand exit status 0
2015-04-27 02:04:02 Command output:
Hit http://dl.firecore.com Release.gpg
Ign http://mirrors.xbmc.org ./ Release.gpg
Ign http://dl.firecore.com Packages/DiffIndex
Hit http://dl.firecore.com Packages
Hit http://apt.awkwardtv.org stable Release.gpg
Hit http://apt.awkwardtv.org stable/main Packages/DiffIndex
Ign http://mirrors.xbmc.org ./ Packages/DiffIndex
Hit http://mirrors.xbmc.org ./ Packages
Reading package lists…
2015-04-27 02:04:02 executing remote command “apt-get -y install com.firecore.maintenance”
2015-04-27 02:04:02 ExecuteRemoteCommand exec rc 0
2015-04-27 02:04:02 ExecuteRemoteCommand exit status 100
Building dependency tree…
E: The package cydia needs to be reinstalled, but I can’t find an archive for it.
2015-04-27 02:04:02 executing remote command “dpkg --configure -a”
2015-04-27 02:04:03 ExecuteRemoteCommand read rc 0
2015-04-27 02:04:03 ExecuteRemoteCommand exit status 0
2015-04-27 02:04:03 executing remote command “apt-get -y install com.firecore.maintenance”
2015-04-27 02:04:03 ExecuteRemoteCommand exec rc 0
2015-04-27 02:04:03 ExecuteRemoteCommand exit status 100
2015-04-27 02:04:03 Command output:
2015-04-27 02:04:03 executing remote command “apt-get -fy install --force-yes”
2015-04-27 02:04:03 -[SshUploadService uploadSynchronously] shutdown
2015-04-27 02:04:03 -[SshUploadService startFileUploadToHostIP:userName:userPassword:localFilePath:remoteFilePath:synchronous:] result 9
2015-04-27 02:04:03 -[AppleTVInstallerUploadPluginPane sshUploadServiceFailed:] service <SshUploadService: 0x7fcedcd8f0f0> result 9 executionError 100
2015-04-27 02:04:03 -[AppleTVInstallerUploadPluginPane showPaneControlType:] type 3
2015-04-27 02:04:03 -[AppleTVInstallerPluginPane timerEvent]
2015-04-27 02:06:48 -[VersionCheckPluginPane willEnterPane:]
2015-04-27 02:06:48 -[VersionCheckPluginPane sendRequest]
2015-04-27 02:06:48 -[VersionCheckPluginPane connectionDidFinishLoading:]
2015-04-27 02:06:48 Current version = 2.5, latest version = 2.5
2015-04-27 02:06:48 -[VersionCheckPluginPane showSuccess]
2015-04-27 02:06:54 -[AppleTVInstallerPluginPane willEnterPane:]
2015-04-27 02:06:54 -[AppleTVInstallerPluginPane startSearch]
2015-04-27 02:06:54 -[AppleTVInstallerPluginPane netServiceBrowser:didFindService:moreComing:] service <NSNetService 0x7f9abb7b6f20> local. _raop._tcp. B817C2CEFDB0@Apple TV
2015-04-27 02:06:54 -[AppleTVInstallerPluginPane netServiceBrowser:didFindService:moreComing:] service <NSNetService 0x7f9abb004320> local. _raop._tcp. 00F76FD7559D@AirPort Express van Walter
2015-04-27 02:06:55 -[AppleTVInstallerPluginPane serviceObjectResolutionList:finishedWithNewServiceObjects:] services (
“<ServiceObject: 0x7f9ab8e0f330>Apple TV (192.168.0.63)”
2015-04-27 02:06:55 -[AppleTVInstallerPluginPane setupPaneControlType:] type 1
2015-04-27 02:06:59 -[AppleTVInstallerPluginPane shouldExitPane:]
2015-04-27 02:06:59 -[AppleTVInstallerPluginPane shouldExitPane:] count 1 selected 0
2015-04-27 02:06:59 -[AppleTVInstallerPluginPane shouldExitPane:] set ip 192.168.0.63 port 5000
2015-04-27 02:06:59 Installer Settings = <SharedSettings: 0x7f9abb589450>
2015-04-27 02:06:59 -[AppleTVInstallerUploadPluginPane willEnterPane:] upload 0
2015-04-27 02:06:59 Upload settings = <SharedSettings: 0x7f9abb589450>
2015-04-27 02:06:59 -[AppleTVInstallerUploadPluginPane showPaneControlType:] type 1
2015-04-27 02:07:00 -[AppleTVInstallerUploadPluginPane uploadFiles]
2015-04-27 02:07:00 Source = /tmp/com.apple.installerBcXoeea1/AppleTVInstallerUploadPlugin.bundle/Contents/Resources/payload.tar
2015-04-27 02:07:00 -[AppleTVInstallerUploadPluginPane uploadFiles] service <SshUploadService: 0x7f9abd80f850> ip 192.168.0.63
2015-04-27 02:07:00 -[SshUploadService startFileUploadToHostIP:userName:userPassword:localFilePath:remoteFilePath:synchronous:] ip 192.168.0.63
2015-04-27 02:07:00 Host ip = 192.168.0.63
2015-04-27 02:07:00 -[SshUploadService uploadSynchronously] testing connection to port 5000
2015-04-27 02:07:00 -[SshUploadService uploadSynchronously] test connection succeded
2015-04-27 02:07:00 Fingerprint:
2015-04-27 02:07:00 executing remote command “mkdir -p /User/tmp”
2015-04-27 02:07:00 ExecuteRemoteCommand exec rc 0
2015-04-27 02:07:01 ExecuteRemoteCommand read rc 0
2015-04-27 02:07:01 ExecuteRemoteCommand exit status 0
2015-04-27 02:07:01 executing remote command “tar -C /User/tmp/ -xvf /User/tmp/payload.tar”
2015-04-27 02:07:01 ExecuteRemoteCommand exec rc 0
2015-04-27 02:07:01 Command output:
2015-04-27 02:07:01 executing remote command “dpkg -i /User/tmp/com.firecore.sources_1.0.deb”
2015-04-27 02:07:01 executing remote command “dpkg -i /User/tmp/org.awkwardtv_0-1.deb”
2015-04-27 02:07:02 ExecuteRemoteCommand read rc 0
2015-04-27 02:07:02 ExecuteRemoteCommand exit status 0
2015-04-27 02:07:02 Command output:
2015-04-27 02:07:02 executing remote command “dpkg -i /User/tmp/org.xbmc.repo_0-1.deb”
2015-04-27 02:07:02 ExecuteRemoteCommand exec rc 0
2015-04-27 02:07:02 executing remote command “apt-get -y update”
2015-04-27 02:07:14 ExecuteRemoteCommand read rc 0
2015-04-27 02:07:14 ExecuteRemoteCommand exit status 0
2015-04-27 02:07:14 Command output:
2015-04-27 02:07:14 executing remote command “apt-get -y install com.firecore.maintenance”
2015-04-27 02:07:14 ExecuteRemoteCommand exec rc 0
2015-04-27 02:07:15 ExecuteRemoteCommand read rc 0
2015-04-27 02:07:15 ExecuteRemoteCommand exit status 100
2015-04-27 02:07:15 Command output:
2015-04-27 02:07:15 executing remote command “dpkg --configure -a”
2015-04-27 02:07:15 ExecuteRemoteCommand exec rc 0
2015-04-27 02:07:15 ExecuteRemoteCommand exit status 0
2015-04-27 02:07:15 executing remote command “apt-get -y install com.firecore.maintenance”
2015-04-27 02:07:15 executing remote command “apt-get -fy install --force-yes”
2015-04-27 02:07:15 -[SshUploadService uploadSynchronously] shutdown
2015-04-27 02:07:15 -[SshUploadService startFileUploadToHostIP:userName:userPassword:localFilePath:remoteFilePath:synchronous:] result 9
2015-04-27 02:07:15 -[AppleTVInstallerUploadPluginPane sshUploadServiceFailed:] service <SshUploadService: 0x7f9abd80f850> result 9 executionError 100
2015-04-27 02:07:15 -[AppleTVInstallerUploadPluginPane showPaneControlType:] type 3
2015-04-27 02:07:15 -[AppleTVInstallerPluginPane timerEvent]
solved it by re jailbreaking again
