Hi
Getting error over and over again 21 and 1611 when sp tries to restore it, it wont get restored, tried diffrent usb cables, redownload the seasonpass, reinstall itunes, i tried Ireb also with no luck, diffrent usb ports.
the log dont asy thtat much
the log say
The process cannot access the file ‘C:\Documents and Settings\cher\Local Settings\Temp\Seas0nPass\BIN’ because it is being used by another process.
but there is no file in the location…so i have unloaded the antivirus, still no luck, any kind f tip would be appriciated.
the host file have no been altered.
I have looked into the forum for other tips.
It has worked before to do the jailbreak on this pc.
DateTime: 30-07-2012 08:50:37 Message: Application start
DateTime: 30-07-2012 08:50:37 Message: Seas0nPass 0.8.6.7558
DateTime: 30-07-2012 08:50:39 Message: clean up
DateTime: 30-07-2012 08:50:51 Message: Started iTunes exe search
DateTime: 30-07-2012 08:50:51 Message: Using registry view Default
DateTime: 30-07-2012 08:50:51 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 30-07-2012 08:50:51 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 30-07-2012 08:50:51 Message: Found 383 subKeyNames
DateTime: 30-07-2012 08:50:51 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6AD9F5F3-5BD0-4000-BD9C-B536CF86D988}
DateTime: 30-07-2012 08:50:51 Message: Path to iTunes is C:\Program Files\iTunes\iTunes.exe
DateTime: 30-07-2012 08:50:51 Message: Installed iTunes version: “10.6.3.25”. IsCompatible? True
DateTime: 30-07-2012 08:50:53 Message: Started version check
DateTime: 30-07-2012 08:50:53 Message: Seas0nPass version is OK
DateTime: 30-07-2012 08:51:00 Message: Starting download
DateTime: 30-07-2012 08:54:34 Message: Download completed
DateTime: 30-07-2012 08:54:48 Message: Downloaded file moved to Documents folder
DateTime: 30-07-2012 08:54:48 Message: Patching message changed to: Unzipping…
DateTime: 30-07-2012 08:55:20 Message: Patching message changed to: Decrypting ramdisk…
DateTime: 30-07-2012 08:55:20 Message: Running process: .\bin\xpwntool.exe, args: .\UNZIPPED_ORIGINAL\038-4379-031.dmg ipsw/038-4379-031.dmg -iv 2125250914722704700cc735cbe4a3ae -k 9f0a7066672af338ae182f0e4885097e83331004fdbca9d3915fa043b781d935
DateTime: 30-07-2012 08:55:22 Message: Patching message changed to: Patching ramdisk…
DateTime: 30-07-2012 08:55:22 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg extract /usr/sbin/asr .\tmp\asr
DateTime: 30-07-2012 08:55:22 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg mv /usr/sbin/asr /usr/sbin/asr_backup
DateTime: 30-07-2012 08:55:22 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg grow 25690112
DateTime: 30-07-2012 08:55:23 Message: Running process: .\bin\bspatch.exe, args: .\tmp\asr .\tmp\asr.patched .\patches\9B830\asr.patch
DateTime: 30-07-2012 08:55:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg add .\tmp\asr.patched /usr/sbin/asr
DateTime: 30-07-2012 08:55:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg chmod 755 /usr/sbin/asr
DateTime: 30-07-2012 08:55:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg rm /usr/local/standalone/firmware/BasebandAudioParameters.c
DateTime: 30-07-2012 08:55:23 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg rm /usr/local/standalone/firmware/ICE2.Release.bbfw
DateTime: 30-07-2012 08:55:23 Message: Patching message changed to: Encrypting ramdisk…
DateTime: 30-07-2012 08:55:23 Message: Running process: .\bin\xpwntool.exe, args: .\tmp\our.dmg .\output\038-4379-031.dmg -iv 2125250914722704700cc735cbe4a3ae -k 9f0a7066672af338ae182f0e4885097e83331004fdbca9d3915fa043b781d935 -t .\UNZIPPED_ORIGINAL\038-4379-031.dmg
DateTime: 30-07-2012 08:55:24 Message: Patching message changed to: Decrypting file system…
DateTime: 30-07-2012 08:55:24 Message: Running process: .\bin\vfdecrypt.exe, args: -i .\UNZIPPED_ORIGINAL\038-4405-031.dmg -k edb697411e210af363ec602d27e73745e86b426c8f710d0b63efeb5e609072e7920c3846 -o ipsw/038-4405-031.dmg
DateTime: 30-07-2012 08:55:47 Message: Running process: .\bin\dmg-bin.exe, args: extract .\tmp\our-big.dmg .\tmp\our-big-hfsimage.dmg
DateTime: 30-07-2012 08:56:06 Message: Patching message changed to: Patching file system…
DateTime: 30-07-2012 08:56:06 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg grow 696721408
DateTime: 30-07-2012 08:56:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /etc/fstab .\tmp\fstab
DateTime: 30-07-2012 08:56:08 Message: Running process: .\bin\bspatch.exe, args: .\tmp\fstab .\tmp\fstab.patched .\patches\9B830\fstab.patch
DateTime: 30-07-2012 08:56:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /etc/fstab /etc/fstab_backup
DateTime: 30-07-2012 08:56:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\fstab.patched /etc/fstab
DateTime: 30-07-2012 08:56:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /etc/fstab
DateTime: 30-07-2012 08:56:08 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg untar .\tmp\rocky_tar\rocky.tar
DateTime: 30-07-2012 08:56:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /usr/sbin/racoon .\tmp\racoon
DateTime: 30-07-2012 08:56:48 Message: Running process: .\bin\bspatch.exe, args: .\tmp\racoon .\tmp\racoon .\patches\9B830\racoon.patch
DateTime: 30-07-2012 08:56:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\racoon /private/var/audit/rocky-racoon/racoon
DateTime: 30-07-2012 08:56:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 775 /private/var/audit/rocky-racoon/racoon
DateTime: 30-07-2012 08:56:49 Message: Patching message changed to: Installing software…
DateTime: 30-07-2012 08:56:56 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/sbin/rtadvd /usr/sbin/rtadvd_backup
DateTime: 30-07-2012 08:56:56 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg untar .\tmp\cydia\cydia.tar
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\asubstratesafe.deb /private/var/root/Media/Cydia/AutoInstall/asubstratesafe.deb
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/asubstratesafe.deb
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\bsubstrate.deb /private/var/root/Media/Cydia/AutoInstall/bsubstrate.deb
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/bsubstrate.deb
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\awkwardtv.deb /private/var/root/Media/Cydia/AutoInstall/awkwardtv.deb
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/awkwardtv.deb
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.nito.deb /private/var/root/Media/Cydia/AutoInstall/com.nito.deb
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.nito.deb
DateTime: 30-07-2012 08:58:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\org.xbmc.repo_0.1-1_iphoneos-arm.deb /private/var/root/Media/Cydia/AutoInstall/org.xbmc.repo_0.1-1_iphoneos-arm.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/org.xbmc.repo_0.1-1_iphoneos-arm.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\syslogd.deb /private/var/root/Media/Cydia/AutoInstall/syslogd.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/syslogd.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.firecore.seas0npass.deb /private/var/root/Media/Cydia/AutoInstall/com.firecore.seas0npass.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.firecore.seas0npass.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.firecore.seas0npass.deb /private/var/root/Media/Cydia/AutoInstall/nano_2.0.7-5_iphoneos-arm.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/nano_2.0.7-5_iphoneos-arm.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.nito.tssagent_1.0-30_iphoneos-arm.deb /private/var/root/Media/Cydia/AutoInstall/com.nito.tssagent_1.0-30_iphoneos-arm.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.nito.tssagent_1.0-30_iphoneos-arm.deb
DateTime: 30-07-2012 08:58:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mkdir /var/stash
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mkdir /usr/include
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Applications /var/stash/Applications
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Library/Ringtones /var/stash/Ringtones
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Library/Wallpaper /var/stash/Wallpaper
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/bin /var/stash/bin
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/include /var/stash/include
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/lib/pam /var/stash/pam
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/libexec /var/stash/libexec
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/share /var/stash/share
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Applications var/stash/Applications
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Library/Ringtones …/var/stash/Ringtones
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Library/Wallpaper …/var/stash/Wallpaper
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/bin …/var/stash/bin
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/include …/var/stash/include
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/lib/pam …/…/var/stash/pam
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/libexec …/var/stash/libexec
DateTime: 30-07-2012 08:58:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/share …/var/stash/share
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Applications
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Library/Ringtones
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Library/Wallpaper
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/bin
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/include
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/lib/pam
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/libexec
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/share
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\patches\9B830\uncompress /bin/uncompress
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 755 /bin/uncompress
DateTime: 30-07-2012 08:58:49 Message: Patching message changed to: Creating IPSW…
DateTime: 30-07-2012 08:58:49 Message: Running process: .\bin\dmg-bin.exe, args: build .\tmp\our-big-hfsimage.dmg .\output\038-4405-031.dmg
DateTime: 30-07-2012 08:59:42 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\iBSS.k66ap.RELEASE.dfu .\OUTPUT\Firmware\dfu\decrypted_iBSS.dfu -iv 67b821977559b8035887d46d68eb5b7b -k 2f442e98254dde0a75ca8d35ea48644bce9efdeb34332e0ec730e848539acead
DateTime: 30-07-2012 08:59:42 Message: Running process: .\bin\bspatch.exe, args: .\OUTPUT\Firmware\dfu\decrypted_iBSS.dfu .\OUTPUT\Firmware\dfu\patched_iBSS.dfu .\patches\9B830\iBSS.k66ap.RELEASE.patch
DateTime: 30-07-2012 08:59:42 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\patched_iBSS.dfu .\OUTPUT\Firmware\dfu\encrypted_iBSS.dfu -iv 67b821977559b8035887d46d68eb5b7b -k 2f442e98254dde0a75ca8d35ea48644bce9efdeb34332e0ec730e848539acead -t .\OUTPUT\Firmware\dfu\iBSS.k66ap.RELEASE.dfu
DateTime: 30-07-2012 08:59:42 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\iBEC.k66ap.RELEASE.dfu .\OUTPUT\Firmware\dfu\decrypted_iBEC.dfu -iv d12f8e04287683c4e2b67feb5fa6e308 -k 975cf31cc14d83389e8136f68f0c26303d7d1db4b197c5f0a3c12b152cde626f
DateTime: 30-07-2012 08:59:42 Message: Running process: .\bin\bspatch.exe, args: .\OUTPUT\Firmware\dfu\decrypted_iBEC.dfu .\OUTPUT\Firmware\dfu\patched_iBEC.dfu .\patches\9B830\iBEC.k66ap.RELEASE.patch
DateTime: 30-07-2012 08:59:42 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\patched_iBEC.dfu .\OUTPUT\Firmware\dfu\encrypted_iBEC.dfu -iv d12f8e04287683c4e2b67feb5fa6e308 -k 975cf31cc14d83389e8136f68f0c26303d7d1db4b197c5f0a3c12b152cde626f -t .\OUTPUT\Firmware\dfu\iBEC.k66ap.RELEASE.dfu
DateTime: 30-07-2012 08:59:42 Message: Patching message changed to: Compressing IPSW…
DateTime: 30-07-2012 09:00:29 Message: Saving kernelcache.release.k66 and iBSS.k66ap.RELEASE.dfu files
DateTime: 30-07-2012 09:00:29 Message: Directory C:\Documents and Settings\cher\Application Data\Seas0nPass\AppleTV2,1_5.0.2_9B830 recreated successfully
DateTime: 30-07-2012 09:00:29 Message: kernelcache.release.k66 file copied successfully
DateTime: 30-07-2012 09:00:29 Message: iBSS.k66ap.RELEASE.dfu file copied successfully
DateTime: 30-07-2012 09:00:29 Message: iBEC.k66ap.RELEASE.dfu file copied successfully
DateTime: 30-07-2012 09:00:50 Message: Restoring DFU file
DateTime: 30-07-2012 09:00:50 Message: DFU process starting for iBSS.k66ap.RELEASE.dfu iBEC.k66ap.RELEASE.dfu
DateTime: 30-07-2012 09:00:52 Message: Output received: ERROR: The process “iTunes.exe” not found.
DateTime: 30-07-2012 09:00:53 Message: Output received: ERROR: The process “iTunesHelper.exe” not found.
DateTime: 30-07-2012 09:00:53 Message: Output received: ::Waiting for device to enter DFU mode…
DateTime: 30-07-2012 09:01:31 Message: Output received: Initializing libpois0n
DateTime: 30-07-2012 09:01:31 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:01:31 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:01:31 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:01:31 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:01:31 Message: Output received: NO mode set
DateTime: 30-07-2012 09:01:31 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:01:31 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:01:31 Message: Output received: Device must be in DFU mode to continue
DateTime: 30-07-2012 09:01:57 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:01:57 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:01:57 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:01:57 Message: Output received: NO mode set
DateTime: 30-07-2012 09:01:57 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:01:57 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:01:57 Message: Output received: Device must be in DFU mode to continue
DateTime: 30-07-2012 09:01:57 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:01:57 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000000d9b50dcd0e_ibfl:03_srnm:[dcyghzu4ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 30-07-2012 09:01:57 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000000d9b50dcd0e_ibfl:03_srnm:[dcyghzu4ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 30-07-2012 09:01:57 Message: Output received: RecoveryMode2 mode set
DateTime: 30-07-2012 09:02:06 Message: Output received: ::Found device in DFU mode…
DateTime: 30-07-2012 09:02:08 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:02:08 Message: Output received: Device must be in DFU mode to continue
DateTime: 30-07-2012 09:02:08 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:02:08 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:02:08 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000000d9b50dcd0e_ibfl:03_srnm:[dcyghzu4ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 30-07-2012 09:02:08 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000000d9b50dcd0e_ibfl:03_srnm:[dcyghzu4ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 30-07-2012 09:02:08 Message: Output received: RecoveryMode2 mode set
DateTime: 30-07-2012 09:02:08 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:02:08 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:02:08 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:02:08 Message: Output received: NO mode set
DateTime: 30-07-2012 09:02:08 Message: Output received: DFU mode set
DateTime: 30-07-2012 09:02:08 Message: Output received: Checking the device type
DateTime: 30-07-2012 09:02:08 Message: Output received: check_context(100035A1)
DateTime: 30-07-2012 09:02:08 Message: Output received: check_context passed
DateTime: 30-07-2012 09:02:08 Message: Output received: check_context(10002E8C)
DateTime: 30-07-2012 09:02:08 Message: Output received: Preparing to upload limera1n exploit
DateTime: 30-07-2012 09:02:08 Message: Output received: Resetting device counters
DateTime: 30-07-2012 09:02:08 Message: Output received: check_context(100010C9)
DateTime: 30-07-2012 09:02:08 Message: Output received: Sending chunk headers
DateTime: 30-07-2012 09:02:08 Message: Output received: Sending exploit payload
DateTime: 30-07-2012 09:02:08 Message: Output received: Sending fake data
DateTime: 30-07-2012 09:02:08 Message: Output received: check_context(FFFFFFFF)
DateTime: 30-07-2012 09:02:08 Message: Output received: check_context(100034A4)
DateTime: 30-07-2012 09:02:08 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:02:08 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:02:11 Message: Output received: ::Uploading iBSS.k66ap.RELEASE.dfu to the device
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 3.2%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 6.4%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 9.6%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 12.8%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 16.0%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 19.2%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 22.4%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 25.6%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 28.8%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 32.0%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 35.2%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 38.4%
DateTime: 30-07-2012 09:02:11 Message: Output received: check_context passed
DateTime: 30-07-2012 09:02:11 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:02:11 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:02:11 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:02:11 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:02:11 Message: Output received: check_context(003E21E8)
DateTime: 30-07-2012 09:02:11 Message: Output received: Exploit sent
DateTime: 30-07-2012 09:02:11 Message: Output received: Reconnecting to device
DateTime: 30-07-2012 09:02:11 Message: Output received: check_context(FFFFFFFF)
DateTime: 30-07-2012 09:02:11 Message: Output received: Waiting 2 seconds for the device to pop up…
DateTime: 30-07-2012 09:02:11 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:02:11 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:02:11 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:02:11 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:02:11 Message: Output received: DFU mode set
DateTime: 30-07-2012 09:02:11 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:02:11 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:02:11 Message: Output received: irecv_send_file(003E21E8, iBSS.k66ap.RELEASE.dfu, 1)
DateTime: 30-07-2012 09:02:11 Message: Output received: check_context(100025C9)
DateTime: 30-07-2012 09:02:11 Message: Output received: check_context ok
DateTime: 30-07-2012 09:02:11 Message: Output received: file opened
DateTime: 30-07-2012 09:02:11 Message: Output received: buffer allocated
DateTime: 30-07-2012 09:02:11 Message: Output received: file content stored in memory
DateTime: 30-07-2012 09:02:11 Message: Output received: irecv_send_buffer(003E21E8,00A50048,64004,1)
DateTime: 30-07-2012 09:02:11 Message: Output received: check_context(10002899)
DateTime: 30-07-2012 09:02:11 Message: Output received: context checked ok
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 41.6%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 44.8%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 48.0%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 51.2%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 54.4%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 57.6%
DateTime: 30-07-2012 09:02:11 Message: Output received: transfer initiated
DateTime: 30-07-2012 09:02:11 Message: Output received: 32 packets will be sent
DateTime: 30-07-2012 09:02:11 Message: Output received: control transfer with status = 0
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 60.8%
DateTime: 30-07-2012 09:02:11 Message: Output received: ## 64.0%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 67.2%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 70.4%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 73.6%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 76.8%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 80.0%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 83.2%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 86.4%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 89.6%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 92.8%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 96.0%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 99.2%
DateTime: 30-07-2012 09:02:12 Message: Output received: ## 100.0%
DateTime: 30-07-2012 09:02:31 Message: Output received: irecv_send_file result = 0
DateTime: 30-07-2012 09:02:41 Message: Output received: ::Uploading iBEC.k66ap.RELEASE.dfu to the device
DateTime: 30-07-2012 09:02:41 Message: Output received: ## 1.1%
DateTime: 30-07-2012 09:02:41 Message: Output received: ## 2.1%
DateTime: 30-07-2012 09:02:41 Message: Output received: ## 3.2%
DateTime: 30-07-2012 09:02:41 Message: Output received: ## 4.3%
DateTime: 30-07-2012 09:02:41 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:02:41 Message: Output received: check_context passed
DateTime: 30-07-2012 09:02:41 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:02:41 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:02:41 Message: Output received: control transfer with status = 0
DateTime: 30-07-2012 09:02:41 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:02:42 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 5.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:02:42 Message: Output received: check_context passed
DateTime: 30-07-2012 09:02:42 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:02:42 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:02:42 Message: Output received: control transfer with status = 0
DateTime: 30-07-2012 09:02:42 Message: Output received: usb packets sending done, finishing transfer
DateTime: 30-07-2012 09:02:42 Message: Output received: check_context(102A7060)
DateTime: 30-07-2012 09:02:42 Message: Output received: file content sent to device with status = 0
DateTime: 30-07-2012 09:02:42 Message: Output received: check_context(100037CD)
DateTime: 30-07-2012 09:02:42 Message: Output received: Waiting 10 seconds for the device to pop up…
DateTime: 30-07-2012 09:02:42 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:02:42 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:02:42 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:02:42 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:02:42 Message: Output received: DFU mode set
DateTime: 30-07-2012 09:02:42 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:02:42 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:02:42 Message: Output received: irecv_send_file(003E21E8, iBEC.k66ap.RELEASE.dfu, 1)
DateTime: 30-07-2012 09:02:42 Message: Output received: check_context(100025C9)
DateTime: 30-07-2012 09:02:42 Message: Output received: check_context ok
DateTime: 30-07-2012 09:02:42 Message: Output received: file opened
DateTime: 30-07-2012 09:02:42 Message: Output received: buffer allocated
DateTime: 30-07-2012 09:02:42 Message: Output received: file content stored in memory
DateTime: 30-07-2012 09:02:42 Message: Output received: irecv_send_buffer(003E21E8,00A50048,190980,1)
DateTime: 30-07-2012 09:02:42 Message: Output received: check_context(10002899)
DateTime: 30-07-2012 09:02:42 Message: Output received: context checked ok
DateTime: 30-07-2012 09:02:42 Message: Output received: transfer initiated
DateTime: 30-07-2012 09:02:42 Message: Output received: 94 packets will be sent
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 6.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 7.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 8.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 9.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 10.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 11.8%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 12.9%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 13.9%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 15.0%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 16.1%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 17.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 18.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 19.3%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 20.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 21.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 22.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 23.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 24.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 25.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 26.8%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 27.9%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 29.0%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 30.0%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 31.1%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 32.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 33.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 34.3%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 35.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 36.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 37.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 38.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 39.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 40.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 41.8%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 42.9%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 44.0%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 45.0%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 46.1%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 47.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 48.3%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 49.3%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 50.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 51.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 52.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 53.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 54.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 55.8%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 56.8%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 57.9%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 59.0%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 60.1%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 61.1%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 62.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 63.3%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 64.3%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 65.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 66.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 67.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 68.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 69.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 70.8%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 71.8%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 72.9%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 74.0%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 75.1%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 76.1%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 77.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 78.3%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 79.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 80.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 81.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 82.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 83.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 84.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 85.8%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 86.9%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 87.9%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 89.0%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 90.1%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 91.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 92.2%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 93.3%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 94.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 95.4%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 96.5%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 97.6%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 98.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 99.7%
DateTime: 30-07-2012 09:02:42 Message: Output received: ## 100.0%
DateTime: 30-07-2012 09:03:02 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:03:02 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:03:02 Message: Output received: control transfer with status = 0
DateTime: 30-07-2012 09:03:02 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:03:02 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:03:02 Message: Output received: check_context passed
DateTime: 30-07-2012 09:03:02 Message: Output received: irecv_send_file result = 0
DateTime: 30-07-2012 09:03:02 Message: Output received: Checking if device is compatible with this jailbreak
DateTime: 30-07-2012 09:03:02 Message: Output received: Identified device as AppleTV2,1
DateTime: 30-07-2012 09:03:02 Message: Output received: usb packets sending done, finishing transfer
DateTime: 30-07-2012 09:03:02 Message: Output received: check_context(102A7060)
DateTime: 30-07-2012 09:03:02 Message: Output received: file content sent to device with status = 0
DateTime: 30-07-2012 09:03:02 Message: Output received: Exiting libpois0n
DateTime: 30-07-2012 09:03:02 Message: Started iTunes exe search
DateTime: 30-07-2012 09:03:02 Message: Using registry view Default
DateTime: 30-07-2012 09:03:02 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 30-07-2012 09:03:02 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 30-07-2012 09:03:03 Message: Found 383 subKeyNames
DateTime: 30-07-2012 09:03:03 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6AD9F5F3-5BD0-4000-BD9C-B536CF86D988}
DateTime: 30-07-2012 09:03:03 Message: Path to iTunes is C:\Program Files\iTunes\iTunes.exe
DateTime: 30-07-2012 09:03:03 Message: Starting iTunes at path C:\Program Files\iTunes\iTunes.exe
DateTime: 30-07-2012 09:03:09 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:10 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:11 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:12 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:13 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:14 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:15 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:16 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:17 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:18 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:19 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:20 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:21 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:22 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:24 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:25 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:26 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:27 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:28 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:29 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:03:31 Message: Control named “MainForm” found! Handle: Handle: 502F0
DateTime: 30-07-2012 09:03:32 Message: Control named “aTV panel” found! Handle: Handle: 1704B8
DateTime: 30-07-2012 09:03:32 Message: Closing Modal Dialogs
DateTime: 30-07-2012 09:03:32 Message: Control named “Found modal dialog” found! Handle: (null)
DateTime: 30-07-2012 09:03:32 Message: Set iTunes to foreground
DateTime: 30-07-2012 09:03:32 Message: Apple TV panel found! Handle: 1704B8
DateTime: 30-07-2012 09:03:32 Message: Control named “Firmware restore button” found! Handle: Handle: 1904E6
DateTime: 30-07-2012 09:03:32 Message: Restore button found! Handle: 1904E6
DateTime: 30-07-2012 09:03:32 Message: Pressing Shift
DateTime: 30-07-2012 09:03:32 Message: Before Restore Click
DateTime: 30-07-2012 09:03:33 Message: Releasing Shift
DateTime: 30-07-2012 09:03:33 Message: Open File Dialog processing
DateTime: 30-07-2012 09:03:33 Message: Control named “Open File Dialog” found! Handle: (null)
DateTime: 30-07-2012 09:03:33 Message: Looking for another dialog
DateTime: 30-07-2012 09:03:33 Message: Control named “Open File Dialog” found! Handle: Handle: A05A6
DateTime: 30-07-2012 09:03:33 Message: Control named “Path TextBox” found! Handle: Handle: 40574
DateTime: 30-07-2012 09:03:33 Message: Path text box found
DateTime: 30-07-2012 09:03:33 Message: Path value set
DateTime: 30-07-2012 09:03:33 Message: Set dialog as ForegroundWindow and send enter to it
DateTime: 30-07-2012 09:03:33 Message: Work with confirmation dialog
DateTime: 30-07-2012 09:03:34 Message: Control named “Confirmation dialog” found! Handle: Handle: B05A6
DateTime: 30-07-2012 09:03:34 Message: clean up
DateTime: 30-07-2012 09:03:34 Message: After Restore Click
Exception occured
Application: Seas0nPass
Version: 0.8.6.7558
Date: 30-07-2012 09:03:35
Computer name: LENOVO-5D7BCB74
User name: cher
OS: Microsoft Windows NT 5.1.2600 Service Pack 3
Culture: sv-SE
Resolution: {Width=1680, Height=1050}
App up time: 00:13:00.9687500
Exception classes:
System.IO.IOException
Exception messages:
Stack Traces:
at System.IO.Directory.DeleteHelper(String fullPath, String userPath, Boolean recursive)
at System.IO.Directory.Delete(String fullPath, String userPath, Boolean recursive)
at Seas0nPass.Utils.SafeDirectory.<>c__DisplayClass7.<Delete>b__6()
at Seas0nPass.Utils.BaseIOUtils.RepeatActionWithDelay(Action action)
at Seas0nPass.Utils.SafeDirectory.Delete(String name, Boolean recursive)
at Seas0nPass.Utils.MiscUtils.CleanUp()
Loaded Modules:
D:\home\Seas0nPass-win(2)\Seas0nPass.exe 0.8.6.7558
C:\WINDOWS\system32\ntdll.dll 5.1.2600.5755 (xpsp_sp3_gdr.090206-1234)
C:\WINDOWS\system32\mscoree.dll 4.0.31106.0 (Main.031106-0000)
C:\WINDOWS\system32\KERNEL32.dll 5.1.2600.5781 (xpsp_sp3_gdr.090321-1317)
C:\WINDOWS\system32\ADVAPI32.dll 5.1.2600.5755 (xpsp_sp3_gdr.090206-1234)
C:\WINDOWS\system32\RPCRT4.dll 5.1.2600.5795 (xpsp_sp3_gdr.090415-1241)
C:\WINDOWS\system32\Secur32.dll 5.1.2600.5834 (xpsp_sp3_gdr.090624-1305)
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\system32\SHLWAPI.dll 6.00.2900.5912 (xpsp_sp3_gdr.091207-1454)
C:\WINDOWS\system32\GDI32.dll 5.1.2600.5698 (xpsp_sp3_gdr.081022-1932)
C:\WINDOWS\system32\USER32.dll 5.1.2600.5512 (xpsp.080413-2105)
C:\WINDOWS\system32\msvcrt.dll 7.0.2600.5512 (xpsp.080413-2111)
C:\WINDOWS\system32\IMM32.DLL 5.1.2600.5512 (xpsp.080413-2105)
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\clr.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\system32\MSVCR100_CLR0400.dll 10.00.30319.1
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\mscorlib\4ff1f12a08d455f195ba996fe77497c6\mscorlib.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\system32\ole32.dll 5.1.2600.5512 (xpsp.080413-2108)
C:\WINDOWS\system32\MSCTF.dll 5.1.2600.5512 (xpsp.080413-2105)
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\culture.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\nlssorting.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System\161c6f80ad93b0505054d244f1c6243c\System.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Drawing\2fe09cc54a8390b20e380239db34228f\System.Drawing.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\f3cdd09fc0acc85c7febbd2e2ef9c4e5\System.Windows.Forms.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\system32\shfolder.dll 6.00.2900.5512 (xpsp.080413-2105)
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll 6.0 (xpsp.080413-2105)
C:\WINDOWS\system32\comctl32.dll 5.82 (xpsp.080413-2105)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Configuration\ac2cd19f2159d48684e17cbdecfaa3b7\System.Configuration.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xml\2d7c29ad77c15abfa6a8fe6d24840a91\System.Xml.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\system32\version.dll 5.1.2600.5512 (xpsp.080413-2105)
C:\WINDOWS\system32\uxtheme.dll 6.00.2900.5512 (xpsp.080413-2105)
C:\WINDOWS\system32\apphelp.dll 5.1.2600.5512 (xpsp.080413-2105)
C:\WINDOWS\system32\msctfime.ime 5.1.2600.5512 (xpsp.080413-2105)
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6001.22319_x-ww_f0b4c2df\gdiplus.dll 5.2.6001.22319 (vistasp1_ldr.081126-1506)
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll 10.0.30319.1 built by: RTMRel
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Core\85693dfd9ba4905b0fd947fdb51446d5\System.Core.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\system32\rsaenh.dll 5.1.2600.5507 (xpsp.080318-1711)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Runtime.Seri#\30ed505f7ea7d6139128d4a6d9981dc0\System.Runtime.Serialization.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\SMDiagnostics\b420437eca1d1aec1a8bf23cc5173661\SMDiagnostics.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Runtime.Dura#\591cc2015a0165ede73d3e6770e0e7c2\System.Runtime.DurableInstancing.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\system32\OLEAUT32.dll 5.1.2600.5512
C:\WINDOWS\system32\xpsp2res.dll 5.1.2600.5512 (xpsp.080413-2113)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIAutomationClient\00798a39f87603ae67392c44f85b1957\UIAutomationClient.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\system32\UIAutomationCore.dll 6.0.6001.17014 (lh_tools_devdiv_wpf.071009-1109)
C:\WINDOWS\system32\OLEACC.dll 4.2.5406.0 (xpclient.010817-1148)
C:\WINDOWS\system32\MSVCP60.dll 6.02.3104.0
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIAutomationProvider\b56a80a51f412ce3832eddecb9bf1580\UIAutomationProvider.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIAutomationTypes\bbd68c1c06eb762bedb74bc73dc9a414\UIAutomationTypes.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIAutomationClients#\f307842a5d932b4c92a71a1b77d1148b\UIAutomationClientsideProviders.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Accessibility\46c8b155e6fcd5696ffa15a67824ebab\Accessibility.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\WindowsBase\f1f3a74eb37b27b7d05b8ffa941f8473\WindowsBase.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xml.Linq\0a5fb7acbda333f46ef269b56b063562\System.Xml.Linq.ni.dll 4.0.30319.1 built by: RTMRel
C:\WINDOWS\system32\rasapi32.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\rasman.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\NETAPI32.dll 5.1.2600.5694 (xpsp_sp3_gdr.081015-1312)
C:\WINDOWS\system32\WS2_32.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\WS2HELP.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\TAPI32.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\rtutils.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\WINMM.dll 5.1.2600.5512 (xpsp.080413-0845)
C:\WINDOWS\system32\msv1_0.dll 5.1.2600.5876 (xpsp_sp3_gdr.090909-1234)
C:\WINDOWS\system32\cryptdll.dll 5.1.2600.5512 (xpsp.080413-2113)
C:\WINDOWS\system32\iphlpapi.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\mswsock.dll 5.1.2600.5625 (xpsp_sp3_gdr.080620-1249)
C:\WINDOWS\system32\hnetcfg.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\System32\wshtcpip.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\DNSAPI.dll 5.1.2600.5625 (xpsp_sp3_gdr.080620-1249)
C:\WINDOWS\System32\winrnr.dll 5.1.2600.5512 (xpsp.080413-2113)
C:\WINDOWS\system32\WLDAP32.dll 5.1.2600.5512 (xpsp.080413-2113)
C:\Program Files\Bonjour\mdnsNSP.dll 3,0,0,10
C:\WINDOWS\system32\rasadhlp.dll 5.1.2600.5512 (xpsp.080413-0852)
C:\WINDOWS\system32\btmmhook.dll 5.5.0.3100
C:\WINDOWS\system32\USERENV.dll 5.1.2600.5512 (xpsp.080413-2113)
C:\WINDOWS\system32\shell32.dll 6.00.2900.6018 (xpsp_sp3_gdr.100726-1746)
C:\WINDOWS\system32\CLBCATQ.DLL 2001.12.4414.700
C:\WINDOWS\system32\COMRes.dll 2001.12.4414.700
C:\WINDOWS\system32\iertutil.dll 7.00.6000.17080 (vista_gdr.100616-0452)
C:\WINDOWS\system32\SETUPAPI.dll 5.1.2600.5512 (xpsp.080413-2111)
C:\WINDOWS\system32\urlmon.dll 7.00.6000.17080 (vista_gdr.100616-0452)
C:\WINDOWS\system32\msi.dll 3.1.4001.5512
C:\WINDOWS\system32\SXS.DLL 5.1.2600.5512 (xpsp.080413-2111)
C:\WINDOWS\system32\Actxprxy.dll 6.00.2900.5512 (xpsp.080413-2113)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Runtime.Remo#\9a7bb1e3cbae28550d7e796e9162dc58\System.Runtime.Remoting.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\WINDOWS\system32\psapi.dll 5.1.2600.5512 (xpsp.080413-2105)
Exception occured
Version: 0.8.6.7558
Date: 30-07-2012 09:03:36
User name: cher
Culture: sv-SE
App up time: 00:13:01.8906250
Exception classes:
Exception messages:
Stack Traces:
at Seas0nPass.Utils.MiscUtils.RecreateDirectory(String dirPath)
Loaded Modules:
DateTime: 30-07-2012 09:23:46 Message: Application Exit
DateTime: 30-07-2012 09:23:46 Message: clean up
DateTime: 30-07-2012 09:28:07 Message: Application start
DateTime: 30-07-2012 09:28:07 Message: Seas0nPass 0.8.6.7558
DateTime: 30-07-2012 09:28:07 Message: clean up
DateTime: 30-07-2012 09:28:14 Message: Started iTunes exe search
DateTime: 30-07-2012 09:28:14 Message: Using registry view Default
DateTime: 30-07-2012 09:28:14 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 30-07-2012 09:28:14 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 30-07-2012 09:28:14 Message: Found 383 subKeyNames
DateTime: 30-07-2012 09:28:14 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6AD9F5F3-5BD0-4000-BD9C-B536CF86D988}
DateTime: 30-07-2012 09:28:14 Message: Path to iTunes is C:\Program Files\iTunes\iTunes.exe
DateTime: 30-07-2012 09:28:14 Message: Installed iTunes version: “10.6.3.25”. IsCompatible? True
DateTime: 30-07-2012 09:28:15 Message: Started version check
DateTime: 30-07-2012 09:28:15 Message: Seas0nPass version is OK
DateTime: 30-07-2012 09:28:24 Message: Original firmware found on disk
DateTime: 30-07-2012 09:28:27 Message: Patching message changed to: Unzipping…
DateTime: 30-07-2012 09:28:55 Message: Patching message changed to: Decrypting ramdisk…
DateTime: 30-07-2012 09:28:55 Message: Running process: .\bin\xpwntool.exe, args: .\UNZIPPED_ORIGINAL\038-4379-031.dmg ipsw/038-4379-031.dmg -iv 2125250914722704700cc735cbe4a3ae -k 9f0a7066672af338ae182f0e4885097e83331004fdbca9d3915fa043b781d935
DateTime: 30-07-2012 09:28:56 Message: Patching message changed to: Patching ramdisk…
DateTime: 30-07-2012 09:28:56 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg extract /usr/sbin/asr .\tmp\asr
DateTime: 30-07-2012 09:28:56 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg mv /usr/sbin/asr /usr/sbin/asr_backup
DateTime: 30-07-2012 09:28:56 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg grow 25690112
DateTime: 30-07-2012 09:28:56 Message: Running process: .\bin\bspatch.exe, args: .\tmp\asr .\tmp\asr.patched .\patches\9B830\asr.patch
DateTime: 30-07-2012 09:28:57 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg add .\tmp\asr.patched /usr/sbin/asr
DateTime: 30-07-2012 09:28:57 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg chmod 755 /usr/sbin/asr
DateTime: 30-07-2012 09:28:57 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg rm /usr/local/standalone/firmware/BasebandAudioParameters.c
DateTime: 30-07-2012 09:28:57 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg rm /usr/local/standalone/firmware/ICE2.Release.bbfw
DateTime: 30-07-2012 09:28:57 Message: Patching message changed to: Encrypting ramdisk…
DateTime: 30-07-2012 09:28:57 Message: Running process: .\bin\xpwntool.exe, args: .\tmp\our.dmg .\output\038-4379-031.dmg -iv 2125250914722704700cc735cbe4a3ae -k 9f0a7066672af338ae182f0e4885097e83331004fdbca9d3915fa043b781d935 -t .\UNZIPPED_ORIGINAL\038-4379-031.dmg
DateTime: 30-07-2012 09:28:58 Message: Patching message changed to: Decrypting file system…
DateTime: 30-07-2012 09:28:58 Message: Running process: .\bin\vfdecrypt.exe, args: -i .\UNZIPPED_ORIGINAL\038-4405-031.dmg -k edb697411e210af363ec602d27e73745e86b426c8f710d0b63efeb5e609072e7920c3846 -o ipsw/038-4405-031.dmg
DateTime: 30-07-2012 09:29:12 Message: Running process: .\bin\dmg-bin.exe, args: extract .\tmp\our-big.dmg .\tmp\our-big-hfsimage.dmg
DateTime: 30-07-2012 09:29:32 Message: Patching message changed to: Patching file system…
DateTime: 30-07-2012 09:29:32 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg grow 696721408
DateTime: 30-07-2012 09:29:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /etc/fstab .\tmp\fstab
DateTime: 30-07-2012 09:29:34 Message: Running process: .\bin\bspatch.exe, args: .\tmp\fstab .\tmp\fstab.patched .\patches\9B830\fstab.patch
DateTime: 30-07-2012 09:29:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /etc/fstab /etc/fstab_backup
DateTime: 30-07-2012 09:29:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\fstab.patched /etc/fstab
DateTime: 30-07-2012 09:29:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /etc/fstab
DateTime: 30-07-2012 09:29:34 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg untar .\tmp\rocky_tar\rocky.tar
DateTime: 30-07-2012 09:30:16 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /usr/sbin/racoon .\tmp\racoon
DateTime: 30-07-2012 09:30:16 Message: Running process: .\bin\bspatch.exe, args: .\tmp\racoon .\tmp\racoon .\patches\9B830\racoon.patch
DateTime: 30-07-2012 09:30:16 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\racoon /private/var/audit/rocky-racoon/racoon
DateTime: 30-07-2012 09:30:16 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 775 /private/var/audit/rocky-racoon/racoon
DateTime: 30-07-2012 09:30:16 Message: Patching message changed to: Installing software…
DateTime: 30-07-2012 09:30:19 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/sbin/rtadvd /usr/sbin/rtadvd_backup
DateTime: 30-07-2012 09:30:19 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg untar .\tmp\cydia\cydia.tar
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\asubstratesafe.deb /private/var/root/Media/Cydia/AutoInstall/asubstratesafe.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/asubstratesafe.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\bsubstrate.deb /private/var/root/Media/Cydia/AutoInstall/bsubstrate.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/bsubstrate.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\awkwardtv.deb /private/var/root/Media/Cydia/AutoInstall/awkwardtv.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/awkwardtv.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.nito.deb /private/var/root/Media/Cydia/AutoInstall/com.nito.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.nito.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\org.xbmc.repo_0.1-1_iphoneos-arm.deb /private/var/root/Media/Cydia/AutoInstall/org.xbmc.repo_0.1-1_iphoneos-arm.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/org.xbmc.repo_0.1-1_iphoneos-arm.deb
DateTime: 30-07-2012 09:32:13 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\syslogd.deb /private/var/root/Media/Cydia/AutoInstall/syslogd.deb
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/syslogd.deb
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.firecore.seas0npass.deb /private/var/root/Media/Cydia/AutoInstall/com.firecore.seas0npass.deb
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.firecore.seas0npass.deb
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.firecore.seas0npass.deb /private/var/root/Media/Cydia/AutoInstall/nano_2.0.7-5_iphoneos-arm.deb
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/nano_2.0.7-5_iphoneos-arm.deb
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.nito.tssagent_1.0-30_iphoneos-arm.deb /private/var/root/Media/Cydia/AutoInstall/com.nito.tssagent_1.0-30_iphoneos-arm.deb
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.nito.tssagent_1.0-30_iphoneos-arm.deb
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mkdir /var/stash
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mkdir /usr/include
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Applications /var/stash/Applications
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Library/Ringtones /var/stash/Ringtones
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Library/Wallpaper /var/stash/Wallpaper
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/bin /var/stash/bin
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/include /var/stash/include
DateTime: 30-07-2012 09:32:14 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/lib/pam /var/stash/pam
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/libexec /var/stash/libexec
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/share /var/stash/share
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Applications var/stash/Applications
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Library/Ringtones …/var/stash/Ringtones
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Library/Wallpaper …/var/stash/Wallpaper
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/bin …/var/stash/bin
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/include …/var/stash/include
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/lib/pam …/…/var/stash/pam
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/libexec …/var/stash/libexec
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/share …/var/stash/share
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Applications
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Library/Ringtones
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Library/Wallpaper
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/bin
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/include
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/lib/pam
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/libexec
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/share
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\patches\9B830\uncompress /bin/uncompress
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 755 /bin/uncompress
DateTime: 30-07-2012 09:32:15 Message: Patching message changed to: Creating IPSW…
DateTime: 30-07-2012 09:32:15 Message: Running process: .\bin\dmg-bin.exe, args: build .\tmp\our-big-hfsimage.dmg .\output\038-4405-031.dmg
DateTime: 30-07-2012 09:33:06 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\iBSS.k66ap.RELEASE.dfu .\OUTPUT\Firmware\dfu\decrypted_iBSS.dfu -iv 67b821977559b8035887d46d68eb5b7b -k 2f442e98254dde0a75ca8d35ea48644bce9efdeb34332e0ec730e848539acead
DateTime: 30-07-2012 09:33:06 Message: Running process: .\bin\bspatch.exe, args: .\OUTPUT\Firmware\dfu\decrypted_iBSS.dfu .\OUTPUT\Firmware\dfu\patched_iBSS.dfu .\patches\9B830\iBSS.k66ap.RELEASE.patch
DateTime: 30-07-2012 09:33:07 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\patched_iBSS.dfu .\OUTPUT\Firmware\dfu\encrypted_iBSS.dfu -iv 67b821977559b8035887d46d68eb5b7b -k 2f442e98254dde0a75ca8d35ea48644bce9efdeb34332e0ec730e848539acead -t .\OUTPUT\Firmware\dfu\iBSS.k66ap.RELEASE.dfu
DateTime: 30-07-2012 09:33:07 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\iBEC.k66ap.RELEASE.dfu .\OUTPUT\Firmware\dfu\decrypted_iBEC.dfu -iv d12f8e04287683c4e2b67feb5fa6e308 -k 975cf31cc14d83389e8136f68f0c26303d7d1db4b197c5f0a3c12b152cde626f
DateTime: 30-07-2012 09:33:07 Message: Running process: .\bin\bspatch.exe, args: .\OUTPUT\Firmware\dfu\decrypted_iBEC.dfu .\OUTPUT\Firmware\dfu\patched_iBEC.dfu .\patches\9B830\iBEC.k66ap.RELEASE.patch
DateTime: 30-07-2012 09:33:07 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\patched_iBEC.dfu .\OUTPUT\Firmware\dfu\encrypted_iBEC.dfu -iv d12f8e04287683c4e2b67feb5fa6e308 -k 975cf31cc14d83389e8136f68f0c26303d7d1db4b197c5f0a3c12b152cde626f -t .\OUTPUT\Firmware\dfu\iBEC.k66ap.RELEASE.dfu
DateTime: 30-07-2012 09:33:07 Message: Patching message changed to: Compressing IPSW…
DateTime: 30-07-2012 09:33:54 Message: Saving kernelcache.release.k66 and iBSS.k66ap.RELEASE.dfu files
DateTime: 30-07-2012 09:33:54 Message: Directory C:\Documents and Settings\cher\Application Data\Seas0nPass\AppleTV2,1_5.0.2_9B830 recreated successfully
DateTime: 30-07-2012 09:33:54 Message: kernelcache.release.k66 file copied successfully
DateTime: 30-07-2012 09:33:54 Message: iBSS.k66ap.RELEASE.dfu file copied successfully
DateTime: 30-07-2012 09:33:54 Message: iBEC.k66ap.RELEASE.dfu file copied successfully
DateTime: 30-07-2012 09:34:20 Message: Restoring DFU file
DateTime: 30-07-2012 09:34:20 Message: DFU process starting for iBSS.k66ap.RELEASE.dfu iBEC.k66ap.RELEASE.dfu
DateTime: 30-07-2012 09:34:22 Message: Output received: ERROR: The process “iTunes.exe” not found.
DateTime: 30-07-2012 09:34:22 Message: Output received: ERROR: The process “iTunesHelper.exe” not found.
DateTime: 30-07-2012 09:34:22 Message: Output received: ::Waiting for device to enter DFU mode…
DateTime: 30-07-2012 09:35:00 Message: Output received: Initializing libpois0n
DateTime: 30-07-2012 09:35:00 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:35:00 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:35:00 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:35:00 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:35:00 Message: Output received: NO mode set
DateTime: 30-07-2012 09:35:00 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:35:00 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:35:00 Message: Output received: Device must be in DFU mode to continue
DateTime: 30-07-2012 09:35:10 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:35:10 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:35:10 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:35:10 Message: Output received: NO mode set
DateTime: 30-07-2012 09:35:10 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:35:10 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:35:10 Message: Output received: Device must be in DFU mode to continue
DateTime: 30-07-2012 09:35:10 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:35:10 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000000d9b50dcd0e_ibfl:03_srnm:[dcyghzu4ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 30-07-2012 09:35:10 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000000d9b50dcd0e_ibfl:03_srnm:[dcyghzu4ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 30-07-2012 09:35:10 Message: Output received: RecoveryMode2 mode set
DateTime: 30-07-2012 09:35:18 Message: Output received: ::Found device in DFU mode…
DateTime: 30-07-2012 09:35:21 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:35:21 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:35:21 Message: Output received: Device must be in DFU mode to continue
DateTime: 30-07-2012 09:35:21 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:35:21 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:35:21 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000000d9b50dcd0e_ibfl:03_srnm:[dcyghzu4ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 30-07-2012 09:35:21 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000000d9b50dcd0e_ibfl:03_srnm:[dcyghzu4ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 30-07-2012 09:35:21 Message: Output received: RecoveryMode2 mode set
DateTime: 30-07-2012 09:35:21 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:35:21 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:35:21 Message: Output received: NO mode set
DateTime: 30-07-2012 09:35:21 Message: Output received: DFU mode set
DateTime: 30-07-2012 09:35:21 Message: Output received: Checking the device type
DateTime: 30-07-2012 09:35:21 Message: Output received: check_context(100035A1)
DateTime: 30-07-2012 09:35:21 Message: Output received: check_context passed
DateTime: 30-07-2012 09:35:21 Message: Output received: check_context(10002E8C)
DateTime: 30-07-2012 09:35:21 Message: Output received: Preparing to upload limera1n exploit
DateTime: 30-07-2012 09:35:21 Message: Output received: Resetting device counters
DateTime: 30-07-2012 09:35:21 Message: Output received: check_context(100010C9)
DateTime: 30-07-2012 09:35:21 Message: Output received: Sending chunk headers
DateTime: 30-07-2012 09:35:21 Message: Output received: Sending exploit payload
DateTime: 30-07-2012 09:35:21 Message: Output received: Sending fake data
DateTime: 30-07-2012 09:35:21 Message: Output received: check_context(FFFFFFFF)
DateTime: 30-07-2012 09:35:21 Message: Output received: check_context(100034A4)
DateTime: 30-07-2012 09:35:21 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:35:21 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:35:21 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:35:21 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:35:21 Message: Output received: check_context(003E21E8)
DateTime: 30-07-2012 09:35:21 Message: Output received: Exploit sent
DateTime: 30-07-2012 09:35:21 Message: Output received: Reconnecting to device
DateTime: 30-07-2012 09:35:23 Message: Output received: ::Uploading iBSS.k66ap.RELEASE.dfu to the device
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 3.2%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 6.4%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 9.6%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 12.8%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 16.0%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 19.2%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 22.4%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 25.6%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 28.8%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 32.0%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 35.2%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 38.4%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 41.6%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 44.8%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 48.0%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 51.2%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 54.4%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 57.6%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 60.8%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 64.0%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 67.2%
DateTime: 30-07-2012 09:35:23 Message: Output received: Waiting 2 seconds for the device to pop up…
DateTime: 30-07-2012 09:35:23 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:35:23 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:35:23 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:35:23 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:35:23 Message: Output received: DFU mode set
DateTime: 30-07-2012 09:35:23 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:35:23 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:35:23 Message: Output received: irecv_send_file(003E21E8, iBSS.k66ap.RELEASE.dfu, 1)
DateTime: 30-07-2012 09:35:23 Message: Output received: check_context(100025C9)
DateTime: 30-07-2012 09:35:23 Message: Output received: check_context passed
DateTime: 30-07-2012 09:35:23 Message: Output received: check_context ok
DateTime: 30-07-2012 09:35:23 Message: Output received: file opened
DateTime: 30-07-2012 09:35:23 Message: Output received: buffer allocated
DateTime: 30-07-2012 09:35:23 Message: Output received: file content stored in memory
DateTime: 30-07-2012 09:35:23 Message: Output received: irecv_send_buffer(003E21E8,00A50048,64004,1)
DateTime: 30-07-2012 09:35:23 Message: Output received: check_context(10002899)
DateTime: 30-07-2012 09:35:23 Message: Output received: context checked ok
DateTime: 30-07-2012 09:35:23 Message: Output received: transfer initiated
DateTime: 30-07-2012 09:35:23 Message: Output received: 32 packets will be sent
DateTime: 30-07-2012 09:35:23 Message: Output received: control transfer with status = 0
DateTime: 30-07-2012 09:35:23 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:35:23 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:35:23 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:35:23 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 70.4%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 73.6%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 76.8%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 80.0%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 83.2%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 86.4%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 89.6%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 92.8%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 96.0%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 99.2%
DateTime: 30-07-2012 09:35:23 Message: Output received: ## 100.0%
DateTime: 30-07-2012 09:35:43 Message: Output received: irecv_send_file result = 0
DateTime: 30-07-2012 09:35:53 Message: Output received: ::Uploading iBEC.k66ap.RELEASE.dfu to the device
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 1.1%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 2.1%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 3.2%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 4.3%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 5.4%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 6.4%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 7.5%
DateTime: 30-07-2012 09:35:53 Message: Output received: check_context passed
DateTime: 30-07-2012 09:35:53 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:35:53 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:35:53 Message: Output received: control transfer with status = 0
DateTime: 30-07-2012 09:35:53 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:35:53 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:35:53 Message: Output received: usb packets sending done, finishing transfer
DateTime: 30-07-2012 09:35:53 Message: Output received: check_context(102A7060)
DateTime: 30-07-2012 09:35:53 Message: Output received: file content sent to device with status = 0
DateTime: 30-07-2012 09:35:53 Message: Output received: check_context(100037CD)
DateTime: 30-07-2012 09:35:53 Message: Output received: Waiting 10 seconds for the device to pop up…
DateTime: 30-07-2012 09:35:53 Message: Output received: mobiledevice_connect+
DateTime: 30-07-2012 09:35:53 Message: Output received: mobiledevice_openpipes+
DateTime: 30-07-2012 09:35:53 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 30-07-2012 09:35:53 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 30-07-2012 09:35:53 Message: Output received: DFU mode set
DateTime: 30-07-2012 09:35:53 Message: Output received: mobiledevice_openpipes-
DateTime: 30-07-2012 09:35:53 Message: Output received: mobiledevice_connect OK
DateTime: 30-07-2012 09:35:53 Message: Output received: irecv_send_file(003E21E8, iBEC.k66ap.RELEASE.dfu, 1)
DateTime: 30-07-2012 09:35:53 Message: Output received: check_context(100025C9)
DateTime: 30-07-2012 09:35:53 Message: Output received: check_context ok
DateTime: 30-07-2012 09:35:53 Message: Output received: file opened
DateTime: 30-07-2012 09:35:53 Message: Output received: buffer allocated
DateTime: 30-07-2012 09:35:53 Message: Output received: file content stored in memory
DateTime: 30-07-2012 09:35:53 Message: Output received: irecv_send_buffer(003E21E8,00A50048,190980,1)
DateTime: 30-07-2012 09:35:53 Message: Output received: check_context(10002899)
DateTime: 30-07-2012 09:35:53 Message: Output received: context checked ok
DateTime: 30-07-2012 09:35:53 Message: Output received: transfer initiated
DateTime: 30-07-2012 09:35:53 Message: Output received: 94 packets will be sent
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 8.6%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 9.7%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 10.7%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 11.8%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 12.9%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 13.9%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 15.0%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 16.1%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 17.2%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 18.2%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 19.3%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 20.4%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 21.4%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 22.5%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 23.6%
DateTime: 30-07-2012 09:35:53 Message: Output received: ## 24.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 25.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 26.8%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 27.9%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 29.0%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 30.0%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 31.1%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 32.2%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 33.2%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 34.3%
DateTime: 30-07-2012 09:35:54 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:35:54 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:35:54 Message: Output received: check_context passed
DateTime: 30-07-2012 09:35:54 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:35:54 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:35:54 Message: Output received: control transfer with status = 0
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 35.4%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 36.5%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 37.5%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 38.6%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 39.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 40.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 41.8%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 42.9%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 44.0%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 45.0%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 46.1%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 47.2%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 48.3%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 49.3%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 50.4%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 51.5%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 52.5%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 53.6%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 54.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 55.8%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 56.8%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 57.9%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 59.0%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 60.1%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 61.1%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 62.2%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 63.3%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 64.3%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 65.4%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 66.5%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 67.6%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 68.6%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 69.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 70.8%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 71.8%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 72.9%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 74.0%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 75.1%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 76.1%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 77.2%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 78.3%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 79.4%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 80.4%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 81.5%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 82.6%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 83.6%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 84.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 85.8%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 86.9%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 87.9%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 89.0%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 90.1%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 91.2%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 92.2%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 93.3%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 94.4%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 95.4%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 96.5%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 97.6%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 98.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 99.7%
DateTime: 30-07-2012 09:35:54 Message: Output received: ## 100.0%
DateTime: 30-07-2012 09:36:14 Message: Output received: irecv_send_file result = 0
DateTime: 30-07-2012 09:36:14 Message: Output received: Checking if device is compatible with this jailbreak
DateTime: 30-07-2012 09:36:14 Message: Output received: Identified device as AppleTV2,1
DateTime: 30-07-2012 09:36:14 Message: Output received: irecv_get_status control transfer ok
DateTime: 30-07-2012 09:36:14 Message: Output received: control transfer with status = 0
DateTime: 30-07-2012 09:36:14 Message: Output received: irecv_get_status+
DateTime: 30-07-2012 09:36:14 Message: Output received: check_context(10002767)
DateTime: 30-07-2012 09:36:14 Message: Output received: check_context passed
DateTime: 30-07-2012 09:36:14 Message: Output received: irecv_get_status context check ok
DateTime: 30-07-2012 09:36:14 Message: Output received: usb packets sending done, finishing transfer
DateTime: 30-07-2012 09:36:14 Message: Output received: check_context(102A7060)
DateTime: 30-07-2012 09:36:14 Message: Output received: file content sent to device with status = 0
DateTime: 30-07-2012 09:36:14 Message: Output received: Exiting libpois0n
DateTime: 30-07-2012 09:36:14 Message: Started iTunes exe search
DateTime: 30-07-2012 09:36:14 Message: Using registry view Default
DateTime: 30-07-2012 09:36:14 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 30-07-2012 09:36:14 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 30-07-2012 09:36:14 Message: Found 383 subKeyNames
DateTime: 30-07-2012 09:36:14 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{6AD9F5F3-5BD0-4000-BD9C-B536CF86D988}
DateTime: 30-07-2012 09:36:14 Message: Path to iTunes is C:\Program Files\iTunes\iTunes.exe
DateTime: 30-07-2012 09:36:14 Message: Starting iTunes at path C:\Program Files\iTunes\iTunes.exe
DateTime: 30-07-2012 09:36:17 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:18 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:19 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:20 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:21 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:22 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:23 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:24 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:25 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:26 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:27 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:28 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:29 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:30 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:32 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:33 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:34 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:35 Message: Control named “MainForm” found! Handle: (null)
DateTime: 30-07-2012 09:36:37 Message: Control named “MainForm” found! Handle: Handle: B02AC
DateTime: 30-07-2012 09:36:39 Message: Control named “aTV panel” found! Handle: Handle: 180542
DateTime: 30-07-2012 09:36:39 Message: Closing Modal Dialogs
DateTime: 30-07-2012 09:36:39 Message: Control named “Found modal dialog” found! Handle: (null)
DateTime: 30-07-2012 09:36:39 Message: Set iTunes to foreground
DateTime: 30-07-2012 09:36:39 Message: Apple TV panel found! Handle: 180542
DateTime: 30-07-2012 09:36:39 Message: Control named “Firmware restore button” found! Handle: Handle: 1B0540
DateTime: 30-07-2012 09:36:39 Message: Restore button found! Handle: 1B0540
DateTime: 30-07-2012 09:36:39 Message: Pressing Shift
DateTime: 30-07-2012 09:36:39 Message: Before Restore Click
DateTime: 30-07-2012 09:36:39 Message: Releasing Shift
DateTime: 30-07-2012 09:36:39 Message: Open File Dialog processing
DateTime: 30-07-2012 09:36:39 Message: Control named “Open File Dialog” found! Handle: Handle: 8049E
DateTime: 30-07-2012 09:36:39 Message: Control named “Path TextBox” found! Handle: Handle: 70420
DateTime: 30-07-2012 09:36:39 Message: Path text box found
DateTime: 30-07-2012 09:36:39 Message: Path value set
DateTime: 30-07-2012 09:36:39 Message: Set dialog as ForegroundWindow and send enter to it
DateTime: 30-07-2012 09:36:40 Message: Work with confirmation dialog
DateTime: 30-07-2012 09:36:40 Message: Control named “Confirmation dialog” found! Handle: Handle: 9049E
DateTime: 30-07-2012 09:36:40 Message: clean up
DateTime: 30-07-2012 09:36:40 Message: After Restore Click
Exception occured
Version: 0.8.6.7558
Date: 30-07-2012 09:36:41
User name: cher
Culture: sv-SE
App up time: 00:08:34.9062500
Exception classes:
Exception messages:
The process cannot access the file ‘C:\Documents and Settings\cher\Local Settings\Temp\Seas0nPass\BIN’ because it is being used by another process.
Stack Traces:
Loaded Modules:
Exception occured
Version: 0.8.6.7558
Date: 30-07-2012 09:36:42
User name: cher
Culture: sv-SE
App up time: 00:08:35.9375000
Exception classes:
Exception messages:
Stack Traces:
Loaded Modules:
DateTime: 30-07-2012 09:37:24 Message: Application Exit
DateTime: 30-07-2012 09:37:24 Message: clean up
Exception occured
Version: 0.8.6.7558
Date: 30-07-2012 09:37:24
User name: cher
Culture: sv-SE
App up time: 00:09:18.0312500
Exception classes:
Exception messages:
Stack Traces:
Loaded Modules:
