Hi all.
I might be able to help some of you with a fix ive heard from a couple of peeps but am kinda gonna try and give u a quick guide.
I have finally jailbreaked my apple tv using this method.
I had 4.4.4 f/w on my apple tv. When i did the guide that has just come out step by step and open i-tunes i was getting the dreaded 1600 error that everyone is talking about.i upgraded f/w to 5.0 during the course of the day but had the blobs from when it was 4.4.4 (Luck more than anything)
ive also had errors
1604
3194
along with the dreaded 1600.
This is how to get around it.
Download snowbreeze 2.9.3 from here www.ih8sn0w.com/
Open it up. press o.k
then the arrow in bottom right hand corner.
press browse and locate the ipsw (should look like this Appletv2.1_4.4.4_9A406a_Restore)
it will verifiy it. press the arrow button again.
Then select IFaith Mode.
it will then ask for you to locate ShSh blobs.
this should be a long number and at the end should say (9A406a)-blobs.ifaith.
this will process and take about 5mins to work its magic
At the end of this you will have a new custom snowbreeze f/w sitting on your desktop.
then hit o.k on snowbreeze again.
this take you through the DFU Pwner.
Load up i-tune.
Keep hold of shift and press Restore.
find ur new snowbreeze f/w and let it do its magic.
NO more 1600 error at the end.
It take about a min to load up when u plug it back into ur tv. mine a rebooted a few times before it worked.
you will the nito tv sign. all is good
Been working on this apple tv since 9am this morning until now.
Enjoy
Nutmeister
