Hey! Recently just got all my infra behind a Cloudflare tunnel after I read that they’re ok with you doing that if you’re not caching.
Everything works great. Plex on the browser, TV app, mobile app… Flawless. Cloudflare is actually a pretty impressive service.
However, Infuse is not liking it. (Tested on iOS and tv apps, getting the same error)
I thought at first it was something weird with CF, but it works everywhere else and a few things point to Infuse as the problem.
- Using Infuse, if you download manually and play locally, it works. The issue is with streaming content.
- Speed tests work fine within the Plex share
- I can see bandwidth coming out of my Plex server just before error
- When playing around with the playback caching options, changing to anything other than Auto will make the UI unresponsive forcing me to force close the app.
- Again, it works everywhere. iOS and tv Plex apps and browser
File ticket #173951. Just posting here to get more visibility from other people with the same setup!
Cheers!
