That’s not working for me. I’ve tried repeatedly and the metadata won’t clear.
As for the other things you listed, I haven’t changed any settings and the issues are only with the ATV that was updated to 6.3.5. My other ATV is working normally, metadata and all.
I don’t want to derail what you are doing with James but the only poster for that movie is set to french and depending on what you have set for language used for metadata may affect what is fetched also I believe.
Could be, but before the update, that cover was fecthed correctly ?
Let me find other examples.
Edit: Yeah, seems like TMDB is using some ‘new’ covers for some classic movies
Edit 2: I voted for the classic covers and looks like there are the principals right now. Maybe an option inside Infuse to select between available covers? Anyway, thank you for your support
Apparently TMDB has been deleting A LOT of posters, and if your movies had one of those, it got deleted from your library and Infuse doesn’t replace it with another one unless you manually edit each movie.
So now my only options are to “edit” almost every movie in Infuse (over 1600), or to “Clear all metadata” so my entire library (over 7100 items) gets updated.
I won’t be happy with either one but I guess I’ll be better off just clearing all metadata…
It would be nice if Infuse could somehow periodically update data from TMDB and thetvdb so we’re up to date with new posters and info
If you look at the Changes log, you can see that TMDb Bot deleted the English poster on 28th FEB 2020, for reasons that don’t make sense to anyone. (See - TMDb Issues - Mass deletion of Movie Posters)
From my experience though, Infuse will fetch the foreign poster if no English poster is available.
I have just started saving a local copy of every movie poster to my shared folders once I’m happy with the one I have. You can’t trust TMDb to not change posters - It’ll either delete posters, or users will upvote non-original posters to be the default poster at some point. This is why I’m hopeful to get this bug (Can’t change custom poster art. Can only set once) fixed, because it’s causing me issues right now.
