Since v8.1 I guess, I’m seeing the same bug as the one below but on iOS only:
Hitting Play will play the right episode but the focus below is not on the right one as you can see here:
Could you please help to resolve this bug?
After the latest update, I’ve noticed that when I enter a TV show, the episode view no longer automatically selects the next episode based on my current progress.
For example, in previous versions, if I had watched up to episode 6, and then clicked into the TV show, the episode view would automatically highlight episode 7 with an orange box around the preview image.
The play button and episode description are correct, but the issue is with the episode view. The episode that should be played next is not being highlighted with the orange box.
I’m using Plex as my platform, and Infuse is linked to my Plex media library for streaming TV shows.
Is this a bug or is there a setting that needs to be adjusted?
The issue still exists in the latest 8.1.1 version, and it occurs on both iPhone and iPad. For TV shows like Detective Conan, which have over 1000 episodes, this is very inconvenient. Every time I click into the show, the orange box is not selected, and I have to scroll from the first episode to the later ones.
I moved your posts to a thread discussing this issue.
Hi, any news about a fix for this bug? Thanks
