Episode order
Hi, maybe a silly question, but how do I get this in the correct order? So: Bhagya Lakshmi S01E184, Bhagya Lakshmi S01E184-1, Bhagya Lakshmi S01E184-2, Bhagya Lakshmi S01E184-3, and Bhagya Lakshmi S01E184-4? Right now, it’s the opposite.
Looking forward to hearing from you! Thanks in advance!
The naming for correct results can’t be S01Exxx-x Infuse doesn’t recognize the dash (-) as part of the episode number.
You’ll have to use Bhagya Lakshmi S01E184.mp4 then Bhagya Lakshmi S01E185.mp4 then Bhagya Lakshmi S01E186.mp4 and so on
Thanks for your message! The thing is, the episodes that have a dash ‘-’ in the title are actually specials, but they still belong to the main episode lineup. There’s already an episode with number 185 and so on. That’s why I used the dash to differentiate them. Is there another solution for this?
For specials, the files would have a season number of “00” with an episode number after like “Bhagya Lakshmi S00E01.mp4”
TMDB does not have a specials season entered and only shows continuous episode numbers so you may want to consider joining TMDB and entering the correct data so it would work for everyone.
Just make sure that you follow their format and rules since they are very strict about entries so they don’t have to make corrections repeatedly.
Thank you! I do have a TMDB account. Could you tell me exactly what I need to change and what I should enter on TMDB so that the special episodes appear after episode 184 and before episode 185?
The network page for this show does not have any specials, they are all episode numbers in order.
Don’t change things on TMDB to create specials when there aren’t officially any specials. I’d just change the episode numbers on your files to match what the network site has.
Infuse does not support interleaving specials and regular episodes as you have to pick them manually from S0. The only way is to label them sequentially
Thanks for all your help. I made the specific episodes special episodes and started numbering them from 184, so I know I have to watch those before the regular episode 185.
