Enhanced Subtitle Default Options
Right now there is the option to set a default subtitle language, would be cool if you could also set preferences such as Prefer Forced Subtitles, or Prefer CC/SDH Subtitles. A lot of MKV’s have these tracks tagged as Forced/SDH so would be able to rely on those tags to determine which is which.
Good suggestion.
It would also be helpful when downloading subtitles (and trying to find one that syncs up correctly) the subtitle selection menu could tell you which subtitle is which; so you can easily delete the bad ones.
