I jailbroke via SeasonPass and installed new version today at work. Everything worked great. No problems, until I got home. I plug the ATV2 in and I get the Apple Logo on start up, but a black screen after that with a quick flashing light. After a few minutes it reboots and does the same thing all over again.
Hmmm - you may check to ensure you're running the latest version of Seas0nPass (latest version numbers can be found here: http://forum.firecore.com/topic/3759) then re-jailbreak.
Thanks for the quick reply James. I am most definitely using the latest version of Seas0nPass. Not sure what went bump, but I think I’ll do a full restore and try it all again. I’ll let you know how I go.
Same here - I just ordered Beta 5 yesterday and loded it for the first time, everything went great. I then unplugged aTv to move it into the bedroom, and I also got this endless loop problem.
Alrighty…I have restored the ATV and re-jailbreaked and installed Beta5 again. It’s all working again, which is great, however…I do get a low memory warning when I try to play a movie in Media Player!! How long is something stored in memory? Will I have to restart Lowtide everytime to flush it out??
Verb
UPDATE
Nevermind…I see that you guys are working on a fix for 720p mkv.
