Enabling BBC iPlayer in XMBC/Boxee
Hello,
I have head that the BBC iPlayer comes in the latest version of Boxee but I can’t find it (I’m very new to all this!). I live in the UK so shouldn’t have any issues with playing the content. Do I need to download a plugin? If I do, any advice on which one and where do I put it on the Apple TV?
Any advice is gratefully appreciated.
Dei.
it should be loaded by default under video, internet in boxee…
not sure on xbmc because i am not using that app…
if for some reason it is not loaded there is an app option on the menu and you can go in there and see what apps you have loaded and not loaded and load any that you are needing or wanting. also you can add other developers repositories and then their apps will show up as an option to load as well.
