I’m using Emby to redirect to the real addresses stored in STRM files. Now that URL anti-leech protection has been added to the addresses, playback fails.
CODE:9NQX3,please check。
This is likely expected as leech protection typically prevents items from being access directly.
Other clients can access the content normally, but Infuse currently cannot play it
Why was the anti-leeching protection added?
Some people obtained the actual streaming URLs through technical means, causing a significant increase in my bandwidth consumption.
What type of server are you using?
Do you know the details of how the leech protect feature is enabled?
Would you be able to PM me a pair of links to test here?
has send
I found that the CDN authentication system converts Chinese path characters to URL encoding using uppercase letters, while Infuse’s requests use lowercase. Can this be handled?
There is a fix for this coming in the next update (8.1.4).
think you very much
This should be resolved in today’s 8.1.4 update.
