Emby display issues for different folders in connection
In my Emby setup, a single media library consists of two folders. The same media title (for example, Date a Live in the image) has Seasons 1 to 4 and special episodes stored in one folder, while Season 5 is in another folder. In Emby, it is correctly displayed as a single media entry with six different seasons. However, when adding Emby to Infuse and setting it to library mode, the media is split into two separate entries. One entry shows as having 5 seasons, while the other shows as having only 1 season.
@james Can you tell me if this problem can be solved?
What if you add it in direct mode instead of library?
I tried it when the direct mode was first introduced, but I didn’t check whether this issue was resolved at that time. However, I don’t like the UI of the direct mode, so even if it could solve the issue, I wouldn’t consider using it. I would rather have the author fix this issue within the library mode.
Does this appear correctly if you browse the Emby server directly through the Files tab?
