Embedded vs external subtitle
When I play a file with both embedded subtitle and external subtitle file, it always use the external file, and I have to manually change the subtitle. Is it possible to have the embedded subtitle as default?
If expect it to use the external sub. So I guess opinions differ.
Probably sticker and easier to rejig the subtitles in your files, or just remove or temporarily rename the external subs?
