easy I just loaded the ATVFlash and no it doesn’t work…bummer I was hoping it may have been so, it would make the combination of Elagto EYETV and the Flash a great team,hay the rest of you guys and gals leave some messages for the developer to try and work this one out >>>.ya team!
I will add it to our requested feature list. Hopefully we can get something worked out.
you use EVETV USB KEY on your usb solt direct in your appletv?
sorry my english is very poor
[quote=““steve innes””]
[/quote]
but this FrontRow Plug-in
EyeTV.frappliance code
The PTV plugin is only made for the Leopard version of Frontrow. The Apple TV version is a bit different.
We will look into this.
Shouldn’t Home Media Cloud, which comes w/ATVFlash, work with EyeConnect since it is UPnP compatible?
I tried it but so far no luck and I don’t know why.
David
We will look into this.[/quote]
I also have EyeTV running on my AppleTV and would love to have the PyeTV (http://code.google.com/p/pyetv) plugin for the AppleTV
Hi atvflash,
Can I just check that the current status (as of today) is that no Elgato EyeTV USB device works with aTV Flash please?
I have this one (EyeTV for DTT USB with EyeTV v3 software):
and am extremely keen to see this supported as it would add yet another dimension to my AppleTV.
I’d like to understand if there is a way to do this.
Thanks in advance for your clarification,
iMattUK
I can say that MPlayer/Perian lets me watch .eyetv files on an ATV. If you have them saved and use AFP or SMB to share the volume where they are stored, or hook up a USB drive with them, you can view them.
That in itself is good news. Thanks for the info; I can use that.
Would still dearly love to use the device directly on the AppleTV as a PVR though. I’ve been doing some digging and it seems PyeTV is close - Python scripts that integrate EyeTV with Front Row, but only on Macs, not on the AppleTV. There are a couple of other threads on here about it. I’m hoping the atvflash folks are continuing to investigate this option (and if so, thanks :-))
Thats is a feature ihat i miss
its possible to implementing this ?
so i can record on the mac mini and watch on apple tv without convert to watch my tv shows that i watch and then delete…
i hope for this :roll: :?:
i wait and wait and wait, how long if going to implement this feature ?
i need it :roll:
Your answer’s already there above. Record on your Mac Mini then share the .eyetv file over the network. Nothing needs to be implemented.
any news to streaming live tv from eye tv to apple tv ?
the iphone can streaming now, i hope for that on apple tv
