So here’s what I’ve got for all you geniuses out there today.
- 3x Eero 6 Pro routers (hardwired)
- Purchased Eero Secure + that includes a DDNS
- Running Mac OS 12 on a 2018 Intel Mac Mini with external drives
- External drives are being shared via SMB
- A guy that knows just enough to be smarter than the average person but not as smart as 95% of the people on here with a NAS setup.
Now, everything runs beautifully in the house. I can stream 4K content from Infuse no problems. I’d like to start streaming outside of the home occasionally. I had/have a Plex Pass but switched to Infuse because of all the reasons we know and love. I’d like to keep everything in Infuse. I read this article several times. I picked up a DDNS through Eero thinking I could combine one or two other services I already use. Got is set up SUPER easily thought the app. Set up a port forward and reserved an IP for the Mac using their instructions. I could see my Mac using the IP AND THAT’S about as far as I could get. I tried a bunch of things in Infuse to get that going and nothing seemed to work.
*What do I select in “Add Library” to get this to work outside my house?
*Is it possible to just have the one library work both inside and outside the home?
*Will this be just as fast as my current setup
The tutorial states “Remote connections must be setup manually in Infuse, using the ‘Other…’ option in the Available Shares menu.” but I have no ‘other’ option listed there. Anyone else successful doing this with a similar set up as mine?
