For the movies which do not show up correctly automatically in Media Player, I am trying to create Metadata .XML files per the following support article from FireCore:
I am a Mac user and I am having a hard time saving my Metadata .XML files in a format that Media Player recognizes. Does anyone have any suggestion of what Mac software I should use to correctly save these files?
Firecore support provided me with the attached file (you will need to change the extension from .jpg to .xml). You can edit this in TextEdit on your Mac to include the Metadata for your movie. It should then be readable by the Media Player.
