Edit metadata in 5.2?
Hi…
According to the Metadata 101 article (Metadata 101 – Firecore Support) it should be possible to edit incorrect metadata from the app itself. The article says “Making manual corrections (Apple TV) - Step 1: While viewing the incorrectly matched item’s details page, select the ‘Edit’ button” - but I can’t see an Edit button in 5.2 pro.
Is this a 4-only feature, or am I missing something obvious?
Thanks!
Are you using List View by chance? If so, you’ll want to hold select while an item is highlighted to access the Edit option.
That was it :slight_smile: I’m using List View, and had tried that on the parent folder without success - but if you do it on an actual file you get the Edit option.
Thanks :slight_smile:
