Thanks James
When is the next beta going to be available?
OK. Now for the bad news…stutter-stutter etc. Files PLAY with the fixes but MP4’s stutter about every 30 seconds, same as above. Have not tested as a VOB. Play the same file with vlc player with the hard drive attached to my macbook instead of the Airport extreme, no problems. My setup. ATV2 wtih an Airport extreme using a OWC USB hard drive. I have Apple Extreme set to 802.11n (11g/b compatible) Any advantage if I set to 802.11n only at 5ghz? I use the setting I have because when I periodically use my Macbook for Hulu of Fox etc.
Will try with a VOB file.
Beta6 is coming later this month.
Your network is probably fine. What you are describing is an issue with the Beta5 Media Player. Beta6 will have huge performance improvements.
Thanks James. Looking forward to the next Beta. Always like to make sure, so the product gets its proper “respect”, especially when tech support has been so helpful. Sometimes folk just don’t set things right, even an older Mac guy like me. Been one since 1988.
