DVD menu left and right navigation problem
when I press left or right from my apple remote it will not go to the next button but instead go to the third buttton. The problem is that I want to choose the next button . Pls help
I’ve got the same problem with the last couple versions of nitoTV… any answers?
This bug was fixed in the latest 3.4.3 version of aTV Flash.
I’m afraid I am still experiencing this problem with the latest 3.4.3 version of aTV Flash.
I am using the 3.4.3 version. the problem still not solved.
Ditto. Not fixed. It’s not a problem on discs where the buttons are lined up vertically, but if you have to select horizontally, it always jumps ahead two buttons…
3.4.4 still not fix
To solve the problem, try the following:
  1. Run Smart Installer (http://wiki.atvflash.com/index.php?title=NitoTV_Smart_Installer)
  2. Change playback mode to QuickTime in nitoTV > Settings
Tried change to QT in nito still not work
This a known issue with nitoTV and the post 2.1 firmware versions.
It´s actually fixed in nitoTV 0.64 which should arrive in the atv flash package real soon.
You can update right now via “settings” in nitoTV.
cheers
W.
