DV plays in HDR10
Why does Infuse says the file is Dolby Vision (it even shows the DV badge) but plays the file in HDR10?
I have the Dolby Vision option set to limited.
I believe it is querying the header to know if it has potential DV compatibility for the DV notice, but with limited setting it won’t know until playback if it can do the actual DV
So something needs to be fixed because, to me, it should only show the DV badge if it can actually play a file in Dolby Vision in the Limited setting.
I agree, showing a DV tag but playing things in HDR can lead to some confusion. There are improvements in progress for Dolby Vision Profile 8, which could help with these particular files.
You can follow this thread for updates.
