Duration displayed is incorrect for DVD.iso images
When you select a DVD .iso image to play, the duration that is displayed is usually a small value like 1, 2 or 3 minutes rather than the duration of the main feature on the DVD .iso.
I suspect that maybe it is displaying the duration of the “loop” used on DVD menu.
The duration on .mkv and .avi files appears to be correct.
We’ll take a look.
