Duplicates in infuse 7
I just upgraded my Apple TV to the 2021 model, for some reason infuse 7 has duplicate listings for almost all of my movies, every time I clear it and regenerate it again I have the same issue? Nothing else change though, just the new Apple TV.
Are you letting it load everything from iCloud or are you adding shares manually? If you’re adding shares and letting iCloud restore things you can end up with doubles.
Yeah that’s exactly it. I manually added the share but was iCloud syncing, I just deleted the 2nd share and problem solved.
Thanks for the tip, greatly appreciated!
