Hello,
After using Infuse a while I started to create collections. But apart from the collections I made, infuse also create his own collections. So sometimes there is a double collection (the one I made and the one Infuse created). When I want to delete the collection made by Infuse it asks if I want to delete the videofiles. But that is not what I want. I only want to delete all collections, except the ones I made. What can I do?
In Settings, under Collections & Groups, disable “TMDB Collections”.
Those would be the ones automatically created by Infuse (per metadata sourced from TMDB). The ones you create are “Custom Collections”.
