Dropbox Rclone & Synology expert?
Hey guys,
I have a Synology NAS. I’m using CloudSync but seems like they limit the speed with Dropbox. I didn’t have this problem with GD. After a day it’s still syncing only folders no files (650/5xxx).
I read about RClone. Since I have the NAS I wanted to install it on the NAS. The problem is that it require a browser during the SSH installation.
I tried some alternatives but can’t figure it out.
Have someone here has been able to get the token without the browser?
Thanks in advance.
If I recall you can also install Rclone on any PC/laptop that does have a browser and generate the token there.
Then simply copy and paste into ssh on the NAS.
But in the PC/Mac it open the browser and do it automatically. I was thinking to maybe copy the “drive” and paste it in the NAS. I’m doing research because I’m uploading 25TB to Dropbox and for some reason after a day it has been uploading only girders without the file. It’s taking too long. So my best option is to install it in the NAS since it’s always ON & the files are there.
After 7 hours of multiple tutorial I was able to “merge” them & make it work :fire:
hello, I know that on qnap there is an alternative “hybridmount“, I do not know if it works well on the other hand, there may be an alternative on synalogy
Hybridmount: HybridMount | QNAP
