As the last piece of this streaming puzzle, I’m trying to enable nitoTV to “see” my Droboshare for access to all my DVD titles, but am getting the following error message:
Network Mount Failed!
mount_smbfs: could not find mount
point /mnt/Scratch/Volumes/Drobo:
Socket is not connected
Configuration of the Mount Point is as follows:
Mount Name: Drobo Library
Mount Type: smb
Mount Address: 10.0.1.195 (static IP address of droboshare)
Requires Authentication: yes
User Login: (matches Droboshare login)
Password: (matches Droboshare login)
Volume Path: Drobo (root folder on Drobo)
Auto Mount/Custom Path: off
Any ideas? Thanks!
