Dramatic Increase in cache size after switch from TVDB to TMDB
I usually had a cache size of around 2GB, but after the switch to TMDB the cache size has increased to 5.2 GB. I deleted the cache and after the rebuild it is now around 4GB, more or less double the previous size. What could be the reason for this, higher resolution artwork?
A few changes to improve this are coming soon in the 7.1.2 update. :slight_smile:
7.1.2 with a number of cache improvements was just approved by Apple, and is now rolling out on the App Store.
Please give this a try and let us know how it goes.
Note: If you have a larger library it may take a bit of time for Infuse to process the updates for all images.
