Latelely, as in 5.7, I noticed that some files, most of my new files, does not download. I get the warning triangle when I try to download.Restarting download does not work. Other files works flawless on first attempt.
Is there something I need to be aware of?
And please, streamline your wording you mix Synch Download Delete etc.
-I suggest to use Synch/Unsynch for temporary copies on your mobile device.
Delete is to permanently delete the source, wether it is on a server or local device.
Exactly, this is what I find unclear.
I normally I do this in Flight mode just to be sure. I also only share my movies with read-only access, to avoid deletions of my source files.
You should âdeleteâ the local copy in the Archive view if I understod correct.
But the wording would ideally be different than Delete, like Unsych or similar.
Deleting files via the main âFilesâ tab will remove the locally saved copy, and will not affect your streamed videos.
You can also prevent remote files from being deleting altogether by disabling the âFile Managementâ option found in Settings > General. This is disabled by default.
