Downgrade/Upgrade
Hi. I was just going to check here first. I want to upgrade my apple tv to iOS 7, too check everything out. Does anyone know if it would be possible to downgrade back to 5.3 afterwards. With saved signatures / SHSH of course. Thanks!
Yes, you can downgrade to any version signatures you have saved.
[quote="Carpenter940"]
[/quote]
I have never ever jailbroken my ATV2 before (guaranteed), and was on the latest version as of 2 weeks ago. I thought I would try the 5.3 after reading that it still worked in a forum somewhere (not expecting much), and BAM it worked with the 5.3!!!!!
Result.
As Carpenter states I would recommend backing up your blobs before you try, just to be safe, as I wouldn't want you to blame me if it doesn't for some weird reason.
Also note there is nothing worth having on the latest version over a 5.3 jailbreak, trust me :)
