If there is a double tap to pause,it will be better for user
two finger tap on ios will pause
Why not add double tap the screen to pause playback
I know this might have been requested before but I want to suggest this with an explanation.
Double tap for play/pause instead of two-finger tap because when one is holding his/her phone with one hand, it is much easier to double tap via thumb instead of using another hand to do two finger. I think they should be inverted. Two finger tap should crop but double tap should play/pause.
(Also, I barely use crop because I don’t want part of information cut but that might just be me.)
Subtitles:
A subtitle toggle right next to playback controls would be very cool so that I won’t have to go through the menu just to toggle it for one line.
Loving Infuse. The best media player experience.
Any plans for a Windows 10 version?
would love to have features like
Double Tap To Play/Pause
AND
Seek Time Button.
Thanks.
I moved your post to a currently running thread requesting this feature.
Don’t forget that you need to click the like button on the first post in this thread to show your support for this suggestion! ![]()
