Dolby vision
Hello
Have a quick question I have a nvida shield pro and I use makemkv for my uhd rips when I play them on my shield I get dolby vision. If I play the same file on my new 4K Apple TV with infuse I only get HDR is there a setting I need to enable on my Apple TV or infuse
Apple TV (and Infuse) only support Profile 5 Dolby Vision, which is not what you would have with UHD rips+MakeMKV.
What profile is makemkv outputting?
Profile 7
is it the same on ios and ipads?
Definitely
