I am attempting to get my Gladiator 4KUHD movie to work in Dolby Vision (vs HDR10).
I have used DVDFab to rip them to single layer. See below for media info at the bottom.
When I play this via infuse 6.2 w/ATV4K to a Sony A1E, I never see the Dolby Vision symbol (that might be expected with Sony’s ?) and I see a picture but it will pixelate for many of the frames but I can see content in the other frames.
The HDR10 rip works fine.
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/isom/dby1)
File size : 50.1 GiB
Duration : 2h 50mn
Overall bit rate mode : Variable
Overall bit rate : 42.0 Mbps
Movie name : GLADIATOR.Title391
Recorded date : 2006
Encoded date : UTC 2019-10-31 21:32:53
Tagged date : UTC 2019-10-31 22:03:33
Writing application : DVDFab 11.0.5.4
Cover : Yes
IsTruncated : Yes
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Duration : 2h 50mn
Bit rate : 41.5 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 (24000/1001) fps
Minimum frame rate : 23.952 fps
Maximum frame rate : 24.000 fps
Bits/(Pixel*Frame) : 0.209
Stream size : 49.6 GiB (99%)
Tagged date : UTC 2019-10-31 22:03:32
Codec configuration box : hvcC+dvcC
AFAIK, Sony’s don’t show an input type logo when switching…so I think it’s normal not to see anything after the switch. Some TVs like LG do show a logo for HDR and DV.
As a quick test, you might try playing one of the Dolby Vision samples from the link below to see if you get the DV logo on your Sony.
Since the rip didn’t even work with VLC (same results), I determined that the rip must have been bad.
I used the Mac version of DVDFab (bad rip) and decided that I would try the windows version and did the rip from UHD ISO dual layer to single layer again.
I definitely have a good rip (compared to the previous one) with the windows version. this mp4 plays fine on VLC .
When I try it with infuse 6.2 and the apple tv 4k, it appears to be running at different frame rate than the film is shot and no Dolby Vision emblem comes up. I have dolby enabled and have frame rate and what ever else as matched.
When I force to Dolby Vision 4k at 24fps (match off, manual set) for the apple tv , the movie plays at least at the right speed and looks fine. Not sure how I can tell if Dolby Vision is “working” when I have it forced Dolby vision on for all content.
Maybe I will get the apple tv developer menu on to see what is going on.
The Developer HUD doesn’t show any info when using Infuse player (must be a custom one).
When I have frame matching, dynamic range matching, infuse/apple tv doesn’t seem to honor it. As far as I can tell, if I set it manually to Dolby Vision, 4K and 24 fps, it seems to be running correctly. The picture seems to be significantly more colorful and vibrant when I have it manual set correctly.
What can I do next ?
ideo
Format : HEVC
Codec ID : dvhe
Duration : 2h 50mn
Bit rate : 41.6 Mbps
Frame rate mode : Constant
Stream size : 49.7 GiB (96%)
Encoded date : UTC 2019-11-01 21:20:07
Tagged date : UTC 2019-11-01 21:45:09
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : dtsc
Codec ID/Info : Digital Theater Systems
Duration : 2h 50mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Stream size : 1.80 GiB (3%)
Title : English (dts 5.1)
Language : English
Default : Yes
Alternate group : 1
Tagged date : UTC 2019-11-01 21:45:11
I don’t know how to conclude whether it is a bad rip or not.
I can state that if I set this fixed to Dolby Vision and 24FPS, the Gladiator movie is substantially better than non HDR and appears to be better than HDR.
So, at least for the Gladiator movie, I can watch it in DV and I think it is working when I manual switch the primary setting which I normally have as 4K SDR.
To watch DV single layer for this movie:
Rip it from dual layer to single layer with DVDFab Windows version (10 - 01 -2019 version is what I used)
When you want to watch it, go to settings on the Apple TV (audio/video) and go and make sure you have DV enabled and change the primary viewing to DV 4K and 24FPS.
Then, change the apple tv setting back when you are done.
Now, I will see if I can mix/remux in the lossless audio track . Wish I could have an atmos track.
Correction. Use regular AC3 (or LPCM if using a Shield TV). This is supposed to be the limitation with single layer mp4. I’ve read DTS, ATMOS and TrueHD is a no go.
I was able to get the DTSX track into the imperfect Gladiator mp4 and tested out the audio.
The mediainfo is at the bottom.
I noticed when I muxed in the DTSX track via mp4box, the video was no longer marked as Dolby Vision… That surprised me . Given it is a bad rip from a DV perspective, I am not sure what that means since I never had a proper rip. I played the video in a forced manner and it seemed DV.
The audio track is definitely 7:1 when I check my avr so I think I believe I am playing a lossless DTS HA track but given that the Apple TV converts everything to LPCM I can’t tell other than it is 7.1 vs a 5.1
Unfortunately, Gladiator has many m2ts (vs 1 for the movie) and there is a theatrical version and a extended version. I think I have to figure out which m2ts go with which video and then assemble them as one big m2ts. For this exercise, I just took the biggest/longest one and muxed it in. The audio is fine but it a random audio track that doesn’t go along with the movie in sequence.
So, I will have to take some time and figure out how to assembly the “right audio” and mux that into the mp4.
I have done John Wick 3 and will post my findings for Gladiator
Format : MPEG-4
Codec ID : mp42 (isom/mp42/dby1)
File size : 50.7 GiB
Duration : 2h 50mn
Overall bit rate : 42.5 Mbps
Encoded date : UTC 2019-11-06 04:50:33
Tagged date : UTC 2019-11-06 04:50:33
Video
Format : HEVC
Codec ID : hev1
Duration : 2h 50mn
Maximum bit rate : 99.2 Mbps
Stream size : 49.7 GiB (98%)
Tagged date : UTC 2019-11-06 05:08:39
Audio
Format : DTS XLL X
Commercial name : DTS-HD Master Audio
Codec ID : mp4a-A9
Duration : 19mn 45s
Bit rate mode : Variable
Bit rate : 7 439 Kbps
Maximum bit rate : 9 593 Kbps
Channel(s) : Object Based
Channel layout : Object Based
Stream size : 1.03 GiB (2%)
Default : Yes
Alternate group : 1
I used the same/similar process for John Wick 3 Parabellum as Gladiator above.
The mediainfo is below:
This rip worked ! I get Dolby Vision and the right frame rate automatically and I didn’t get many errors when I read it in through ffmpeg. So, another reason why the Gladiator rip wasn’t right.
Infuse played this one correctly.
I ran into two problems when I tried to mux in the atmos track.
I couldn’t copy just the video stream (w/o the ac-3 track). I got errors with copy just the video.
ffmpeg failed to create the atmos track into the mp4. " AC-3 incompatible with output codec id ‘86060’ ". I will have to look into that.
I decided to create a LPCM 7.1 from the atmos track and was able to mux that in with the video and ac3 track.
When I play it from an audio perspective, I only see 5.1 so I am assuming that I am only playing the ac3 track.
Format : MPEG-4
File size : 58.4 GiB
Duration : 2h 10mn
Overall bit rate : 63.9 Mbps
Movie name : John Wick: Chapter 3 - Parabellum
Genre : Action & Thriller & Crime
Description : Super-assassin John Wick returns with a $14 million price tag on his head and an army of bounty-hunting killers on his trail. After killing a member of the shadowy international assassin’s guild, the High Table, John Wick is excommunicado, but the world’s most ruthless hit men and women await his every turn.
Encoded date : UTC 2019-11-08 13:43:49
Tagged date : UTC 2019-11-08 14:08:52
Writing application : DVDFab 11.0.5.7
Cover : Yes
Title/Sort : John Wick: Chapter 3 - Parabellum
LongDescription : Super-assassin John Wick returns with a $14 million price tag on his head and an army of bounty-hunting killers on his trail. After killing a member of the shadowy international assassin’s guild, the High Table, John Wick is excommunicado, but the world’s most ruthless hit men and women await his every turn.
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Duration : 2h 10mn
Bit rate : 63.2 Mbps
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.318
Stream size : 57.8 GiB (99%)
Encoded date : UTC 2019-11-08 13:43:58
Tagged date : UTC 2019-11-08 14:08:25
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 358 cd/m2
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Duration : 2h 10mn
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 SPF)
Compression mode : Lossy
Stream size : 599 MiB (1%)
Title : English (ac3 5.1)
Language : English
Service kind : Complete Main
Default : Yes
Alternate group : 1
