Hi all,
I have some DV profile 8 files which are HDR10 compatible. To my surprise both QuickTime (although you can never verify since it won’t tell you, thanks Apple) and Infuse will fall back to HDR10 and not do DV.
Is there any way for me to convert the file or are there any updates coming that might change things? Thanks!
