Dolby Vision Brightness on the M4 iPad Pro
Hi everyone,
I know this question has come up before on other forums, but I’ve never seen it answered convincingly. Also, it is not strictly related to Infuse but it is about correctly viewing Dolby Vision content on iPhone/iPad which I can only reliably do with this app.
The way Dolby Vision works on TVs, broadly speaking, is this: when content exceeds the display’s capabilities, the dynamic metadata tells the display how to tone-map the image scene by scene. On OLED TVs, for example, OLED Pixel Brightness is usually set to 100 for HDR/Dolby Vision, and there generally isn’t a reason to lower it. Watching Dolby Vision in a dark room, without ambient compensation, is essentially the intended viewing setup.
On iPads and iPhones, though, things seem much less clear. The brightness slider is something we’re used to adjusting constantly, but it also directly affects how HDR/Dolby Vision content looks.
For a long time, I assumed the brightness slider worked similarly to OLED Pixel Brightness on a TV: setting it to maximum would simply allow the display to reach its full peak brightness, while still respecting the original HDR grade. In other words, I assumed pixels would not become brighter than what the content was actually encoded or graded for.
What I’ve found, however, is that this does not seem to be the case. On the iPad, setting brightness to maximum appears to behave more like an ambient-light compensation feature. Past a certain point, the image becomes noticeably brighter than the original grade. I’ve compared identical frames against Reference Mode, and that seems pretty clear to me.
So my issue is this: where exactly should the brightness slider be set so HDR/Dolby Vision content is displayed no brighter than intended in the dark? And does one slider position produce accurate results across different HDR grades?
This is why I started using Reference Mode in the dark almost religiously for PQ HDR (or Dolby Vision Profile 5 where the dynamic metadata will be ignored) as long as the content is graded at or under 1000 nits. I’ll occasionally watch titles that exceed that, provided the mastering display luminance metadata is still 1000 nits.
But lately I’ve been coming back to the idea of wanting to watch higher-luminance grades accurately by taking advantage of Dolby Vision dynamic metadata.
Does anyone know how this actually works under the hood on Apple devices? Is there any way to get truly accurate Dolby Vision playback in the dark at the correct brightness without Reference Mode? It seems strange to me that iPads and iPhones support Dolby Vision, yet provide no clear default behavior or guidance regarding where the brightness slider should be set in order to view content as intended.
