Dolby Vision and Dolby Atmos banners re-appearing on TV after seeking
Hello,
I have an AppleTV 4K '22 latest version and am using Infuse Pro 7.5.1
When watching Dolby Vision files, every time I seek to a different time, or even 10 seconds rewind or forward, my Tv (LG G3) is displaying “Dolby Vision” and “Dolby Atmos” banners, again and again. It only doesn’t do it when you pause and play without seeking.
I’ve tried DV content on AppleTV+, Amazon Prime and Netflix apps and all of them are normal. I also tried the Plex app on ATv on the same media, playing Dolby Vision, and it’s also fine. The banners only appear once when you select and start playing the video and it doesn’t re-appear when you seek within the file.
This happens on all DV files.
Could you please check if this is bug? If not could you please let me know if there’s any way I can stop this from happening as it’s very annoying.
Thanks,
We have a change coming in 7.5.2 for a similar issue, so it’s possible this may help with what you are seeing.
7.5.2 should be available on the App Store within the next few days.
Thanks James! Looking forward to it. Will upgrade, test and report back.
@james Hello again. Just to report that I upgraded to the latest 7.5.2 version and the behaviour unfortunately persists. How may I help you diagnose what’s causing it?
Would you be able to replicate this issue, and send in a report from your device (and post the 5 digit code here)?
Also, if you’re able to send in a video file you are seeing this issue with that could also be helpful in tracking down what may be going on here.
Sure. Just replicated it and submitted the diagnostics.
The code is YRJEN.
I’ll shortly send a video of the actual behaviour you’ll see in the diagnostics.
Here is the video of the behaviour on 7.5.2 vs Plex on Apple Tv on the same file.
Infuse Pro 7.5.2:
https://streamable.com/z61ykn
Plex:
https://streamable.com/girtel
On the Infuse Pro, I loaded up the file, you’ll see the Dolby Vision and Dolby Atmos banners appearing on the upper right side corner. From that point, as soon as I stop and seek to another point in the file, and press play, you’ll see that the banners are reappearing. Only time this doesn’t happen is if I stop, and play again from the same point.
On the Plex, the banner appears once when the file is first started to play. Same stop - seek- play behaviour does not make the banner appear again.
This happens in any file that plays on Infuse Pro with Dolby Vision or Dolby Atmos.
I read somewhere that this might be related to app losing its “bitstream” when seeking but not sure how reliable this information is tbh.
I’m also wondering if this is specific to the new LG G3 series and the firmware its running. Granted I’m an early adopter so we’ll see if other people experience this as they start buying this new model.
Hope this helps! Please let me know if there’s anything else I can do. That specific video file is quite large (10gb) so let me know if you still need it, happy to upload.
Thanks,
Yargi
Thanks. Will be looking into this.
Thanks James! One additional finding. I just realised that if a DV file does not have DolbyAtmos sound, it looks like the banners behave as they should. Only when a file has DolbyVision and DolbyAtmos sound at the same time, then the banner issue seems to be appearing. This may help you get to the bottom of this.
Also weirdly, app just asked me to unlock DolbyAtmos for free (Included w/ Pro?)two times in the same app session. This never happened before. :thinking:
Are you sure one wasn’t for DTS?
This will explain.
Ah I see, thanks for the explanation. I think it asked for the same format twice but maybe it was different. I’ll check closely if it does it again.
Hey @james , thanks for your time looking into this.
I saw that this issue was included into the upcoming 7.5.3’s list of fixes but then it got dropped. Just wanted to check if this one is being postponed to a later realease or will be a “will not fix” / “working as intended”?
Cheers,
Since this thread is still tagged as ‘in-progress’ it appears it’s just moved back and probably will show up soon.
