Dolby Atmos badge/info for Jellyfin & Plex
Recently movies from Jellyfin are showing the proper info for Dolby Vision ( Dolby Vision titles from Emby & Jellyfin missing DV badge in Infuse ) but the info for Dolby Atmos is still missing. Is it still not possible to pull that info from Jellyfin? When I log into Jellyfin it shows me which titles feature EAC3 with Dolby Atmos in the mediainfo.
I‘m sorry to dig up this old thread, but should this currently work or not?
It’s currently not working, this is a suggestion thread requesting this feature so don’t forget that you need to click the like button on the first post in this thread to show your support for this suggestion! :wink:
Jellfyin is not yet able to identify files with compatible Atmos tracks so Infuse isn’t able to show this info on the details page. Hopefully they’ll be able to add support for this in the future.
Regardless of how the tags appear in Infuse, files with compatible Atmos tracks will play with Atmos when played in Infuse.
Hi James, what do you exactly mean by Jellyfin not able to identify DD+ Atmos? As I wrote above Jellyfin does seem to identify DD+ Atmos correctly. There is also another Apple TV Jellyfin client in TestFlight right now (Neptune) and this app reports DD+ Atmos on the movie pages like expected. Just trying to understand the issue here :slight_smile: :waving_hand:
Hello James! Piggybacking off this post somewhat because I wasn’t sure how to start a new thread. I’m using Plex, not Jellyfin (for now) which I think is still relevant to the discussion. You’ve previously stated that since Plex/Jellyfin/Emby don’t identify Atmos metadata as such, Infuse won’t either. Within the past week or two, Plex has added Atmos identification for both Dolby Digital Plus (EAC3) and TrueHD codecs. Will Infuse now be able to display Atmos on the details page or would that require an additional update to Infuse?
Thank you!!
This has been added in today’s 8.4.7 update. :slight_smile:
Thanks, that was quick :slight_smile: Does this work for TrueHD Atmos as well as DD+Atmos? Only in Library-Mode or als Direct-Mode?
The Atmos tag will be shown for audio tracks which can be played in Atmos on Apple devices, which currently means E-AC3 Atmos only.
Library or Direct Mode.
I keep both Dolby atoms 7.1 true hd, and also eac3 5.1 atmos on most films and set the 5.1 as default track, but infuse shows the 7.1 true hd and ignores the default 5.1 atmos track, is there anyway that infuse can show the default track instead of the one with the most channels.
