Does not load posters for long format series number on thetvdb
Hello, I think I hit a bug in infuse. I created a series on thetvdb with long-form season numbers. Compared to other season I created (00, 01) they seem to never load their artwork. Is it possible this is a bug?
Thank you in advance!
Posters for this series do not load (with seasons like 201605)
https://www.thetvdb.com/series/kodomo-challenge-petit
Posters for this series do load (with seasons like 01)
https://www.thetvdb.com/series/kodomo-challenge-petit-dvd
Can you provide an example of how these files are named?
Yes! Also want to also make clear that the episode names are correctly loading. The images are not.
The episodes are named like this:
ใ“ใจใ‚™ใ‚‚ใกใ‚ƒใ‚Œใ‚“ใ—ใ‚™ใตใ‚šใก - Season 202106 - Episode 06 - ใ‚‚ใฎใฎใชใพใˆ๏ผ’ - ใฎใ‚Šใ‚‚ใฎใพใญใฃใ“
The season poster is on ใ“ใฉใ‚‚ใกใ‚ƒใ‚Œใ‚“ใ˜ใทใก - Aired Order - Season 202106 - TheTVDB.com
It looks like I am losing random data on thetvdb from the screenshots which I am trying to make match the original material. Do I need to move away from Upnp to samba for the local metadata to work?
ping. Any feedback?
I switched from uPnP to samba and the poster.jpg files started working. So this issue is mostly moot for me now.
