Does atv flash allow switching between multiple USB drives?
I’d like to make one 2TB drive for my RipIt! DVD library and another for my iTunes libraries. Will this work? What potential problems will I run into?
Please advise,
Benjamin Rutledge
Sure, you can connect both drives simultaneously using a USB hub. Note: If using an external drive for Primary iTunes storage that drive will need to be connected at all times.
http://wiki.atvflash.com/index.php?title=USB_Storage
That’s very cool. But I just want to clarify: I can have anything I want on all the hard drives I connect, including iTunes media, while still keeping my AppleTV drive as primary. Does that even make sense?
Yes, you can place essentially anything on the drives. However, you may run into issues trying to play iTunes store purchases if they are not being synced through iTunes.
