Do I need to re-jailbreak?
If I update from 4.4.4 to 5.01, is it a straight install or do I need to reset to factory and re-jailbreak?  Can I then reload all my previous settings.
When you flash the jailbroken IPSW for 5.1.1 it will wipe the device anyways.
