divx & xvid sound is jumpy
hi, i’ve just installed version 3.2 after a full restore and software update.
i can connect via ftp and upload files, but any divx or xvid that are up aren’t working! the picture is good, but the sound seems like it’s on slow motion (and when i pause it id screams wired and unpleasant noises). mp4s are working good.
what should i do?
thanks!
The best option for DivX playback is through Sapphire. If you didn’t select Sapphire during installation, these can be played through the DVD plugin as well.
Go into DVD > Settings and change playback mode to Quicktime or mixed.
