Disable startup sound on ATV
Hi
Is there any way you can disable the startup sound and/or sequence on the AppleTV?
Regards
Burns
I don’t think you can disable it completely, but if you press the menu button when the intro movie starts, it will stop the movie playing and go to the main menu.
