Hi … how do I get infuse to stop downloading art work and names ? I’ve disabled everything and it’s still downloading art work and names.
If you want to prevent Infuse from fetching info from online sources like TMDb and TheTVDb, you can disable the ‘Metadata Fetching’ option in settings.
With this disabled, Infuse will fall back to fetching and displaying metadata/artwork that is present inside your videos (or external metadata/artwork present in your folders).
