Directory for AppleTC2,1_4.21_8c...restore.ipsw
What directory is the file held in. I have borrowed a laptop and wanted to try jailbreaking again, the restore.ipsw file is taking all day to download. I can get my created file from my stationary Mac, but i dont know where to put it for Season pass to find and continue.
I'd also like to know where seasonpass is storing it's created file, I searched the filesystem for both but couldn't find anything (quite possible they are deleted after used).
The custom IPSWs are stored in your 'home' folder.
/Users/<your username>
If you want to have Seas0nPass use an IPSW you downloaded manually simply 'Option + click' the Create IPSW button and locate the stock IPSW you wish to use.
Hmm. Let me ask you this. I already had a copy of the ipsw I downloaded from apple in that location. Would seasonpass overwrite it? I'm thinking it didn't and I just kept reflashing the stock firmware.
Would have been helpful for that to have been on the program rather than me having to search the web for 6 hours.
Awesome software though :slight_smile: keep up the good work!
Actually on my MBP SP has been creating the .ipsw file in /Documents/Tethered (it also creates the Tethered folder) and not in my home folder.  But unfortunately it is only putting the un-jailbroken .ipsw from Apple there rather than creating a new jailbroken file.
Seas0nPass will download the standard AppleTV firmware to the Tether folder, and will use this firmware to create the custom firmware.
If you’re not seeing a new IPSW file in your home folder there may be a problem during the jailbreak. If you can send in your log file as described in the link below, we can help troubleshoot.
Log file coming right up:
[log removed]
Thanks. At first glance, your log seems entirely normal.
At this point your best option will be to open a support ticket and submit your log there so we can troubleshoot further.
