Direct mode Jellyfin
But if you activate direct mode in Infuse it usually takes several minutes to show the content, you will only see a big ring in standby.
Also when that ring disappears, about 5 or 10min (it’s the fastest) it still shows the new content with no image on the cover, it’s annoying.
My guess is that something or some function makes Infuse scan something, that’s why it’s slow.
I think for direct mode is that it works like the clients, instantaneous, the server has already done the work.
I don’t know why Infuse is acting like that in direct mode.
Thanks!
A post was merged into an existing topic: Stuck on loading in Home Screen?
